I would like to configure Keycloak so that HSTS header is returned with responses.
Following the advice on enabling https that can be found here: https://hub.docker.com/r/jboss/keycloak/, I have created a certificate which then I have mounted to the container using following command:
-e KEYCLOAK_USER=admin \
-e KEYCLOAK_PASSWORD=admin \
-p 8080:8080 \
-p 8443:8443 \
-p 8444:8444 \
-v /Users/kamil/tmp/https/tls.crt:/etc/x509/https/tls.crt \
-v /Users/kamil/tmp/https/tls.key:/etc/x509/https/tls.key \
--name my-keycloak-test \
my-keycloak
I have also ensured that in the Security defenses tab HSTS settings are correct.
However, when I request a token, responses come without the HSTS header.
Token request:
curl --location --request POST 'https://localhost:8443/auth/realms/test/protocol/openid-connect/token' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--header 'accept: */*' \
--header 'sec-fetch-site: same-site' \
--header 'sec-fetch-mode: cors' \
--data-urlencode 'username=user1' \
--data-urlencode 'grant_type=password' \
--data-urlencode 'client_id=postman' \
--data-urlencode 'redirect_uri=https://google.com' \
--data-urlencode 'password=pass'
I would appreciate any suggestion on what I might be missing here.
