Missing vite\package.json in node_modules during building Keycloak
I’d like to contribute to this awesome project and solve a few open issues. I use Keycloak quite a lot and figured its time to dive deeper into how it works and give something back while doing this.
In order to do so, I try to get keycloak built properly as a first step, of course. Sadly the build runs into the following error:
[INFO] --- frontend:1.14.2:pnpm (pnpm-install) @ keycloak-admin-ui ---
[INFO] Running 'pnpm install --prefer-offline --frozen-lockfile --ignore-scripts' in D:\Workspace\Projekte\GitHub\Keycloak\keycloak\js\apps\admin-ui
[INFO] Scope: all 4 workspace projects
[INFO] ../..                                    | Progress: resolved 1, reused 0, downloaded 0, added 0
[INFO] ../..                                    | +883 ++++++++++++++++++++++++++++++++
[INFO] ../..                                    | Progress: resolved 1, reused 1, downloaded 0, added 1, done
[INFO] â??ENOENTâ?? ENOENT: no such file or directory, open 'xxx\keycloak\js\node_modules\.pnpm\vite@5.1.0_@types+node@20.11.17_lightningcss@1.23.0\node_modules\vite\package.json'
[INFO]
[INFO] pnpm: ENOENT: no such file or directory, open 'xxx\keycloak\js\node_modules\.pnpm\vite@5.1.0_@types+node@20.11.17_lightningcss@1.23.0\node_modules\vite\package.json'
edit: The funnny thing is: If I execute the command
directly in the js/apps/admin-ui directory, it works. So it seems to be a problem, which only occurs during the maven build.
Any ideas? :slight_smile:
If anyone else stumbles over this:
I got it solved by commenting out the line, which deletes the node_modules directory in the maven-clean-plugin of the “js/pom.xml”:
<plugin>
    <groupId>org.apache.maven.plugins</groupId>
    <artifactId>maven-clean-plugin</artifactId>
    <configuration>
        <followSymLinks>false</followSymLinks>
        <filesets>
            <fileset>
                <directory>${basedir}</directory>
                <includes>
                    <include>**/.wireit/**</include>
                    <!-- <include>**/node_modules/**</include> -->
                </includes>
            </fileset>
            <!-- include all non-maven projects here as well -->
            <fileset>
                <directory>apps/keycloak-server</directory>
                <includes>
                    <include>server/**</include>
                </includes>
            </fileset>
        </filesets>
    </configuration>
</plugin>
Appearently the maven-clean-plugin failes to remove the directory entirely and leaves the vite@5.1.0_@types+node@20.11.17_lightningcss@1.23.0 empty. The following step pnpm install --prefer-offline --frozen-lockfile --ignore-scripts of the admin-ui then fails to find this package.json.
