Hello all,
I would like your advise. Currently a custom provider has been implemented with keycloak 21.1.2 for talking to a database. A realm has been created for the users of the company.
Different applications will have access to the same database.
As i have seen, it is recommended to have separate clients (client_id_application_A and client_id_application_A) for each application.
Use case:
Application A creates an access token with scope “openid profile”. Application A calls application B. When the token is generated via the endpoint (realms/{realmName}/protocol/openid-connect/auth) one client_id should be provided. In this case, what is the best approach? Should we have a client per application? How is the best way to generated the token for application A and application B? Should be generated one access token per application?
Thank you in advance!
