I have nginx set up as a reverse proxy and it works I can log in and I have set
keycloak_folder/standalone/configuration/standalone.xml
<http-listener name="default" socket-binding="http" redirect-socket="https" enable-http2="true" proxy-address-forwarding="true" />
however authentication fails in keycloak I have set ssl true for external requests.
so the server looks OK is accesible via Nginx proxy via fqdn>
Any thoughts ?
server_tokens off;
upstream keycloak { ip_hash; server 127.0.0.1:8080; }
server
server_name example.com;
listen 443 ssl http2; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
location /auth
proxy_set_header Host $host;
add_header Access-Control-Allow-Origin *;
proxy_pass http://127.0.0.1;
server
listen 80;
location / { return 301 https://$server_name; }
