I am not able to get KeycloakPrincipal
, when using Keycloak with Spring Security. How do I solve this?
Check if your user principal is an instance of KeycloakPrincipal and than cast it.
Without much information or code examples that’s the only thing I can give you.
HttpServletRequest request = ((ServletRequestAttributes) RequestContextHolder
.currentRequestAttributes()).getRequest();
KeycloakPrincipal keycloakPrincipal = (KeycloakPrincipal) request.getUserPrincipal();
I use it like this:
@RestController
@RequestMapping("/protected")
class ProtectedController {
var logger: Logger = LoggerFactory.getLogger(ProtectedController::class.java)
// @Autowired
// private lateinit var auth: KeycloakSecurityContext
@GetMapping("/message")
fun saySomething(authToken: KeycloakAuthenticationToken, message: String): String {
val principal = authToken.principal as KeycloakPrincipal<KeycloakSecurityContext>
return "Psst: (wisper) $message -> ${principal.name}"
(In Kotlin but you get the idea…)
