Not able to revoke an access token
I am using keycloak revoke end point to revoke a token. I am able to revoke a refresh token but when i am doing it for access token it is giving token_type not supporte. Is this the feature not supported by keycloak?
An Access Token is a data structure that has a lifetime encapsulated in it. So it is supposed to be valid until that time ends - you cannot revoke an access token.
Thats the reason why you want to set a short lifetime into an access token.
here in the Keycloak documentation is descriped how to get an access token via a service account: Server Administration Guide
It is also documented how to revoke it.
I have tried to revoke an access token issued for an service account (Keycloak 13.0.1) - received a 200 from the /revoke endpoint but am still able to use it. Is this a bug or what else needs to be done that the access token is revoked and can’t be used any longer? I see nothing in Keycloak log files.
Here is my sample:
# config
KEYCLOAK_URL=http://localhost:8080/auth
REALM=master
SAMPLE_CLIENT_ID=sample-m2m-client
SAMPLE_CLIENT_SECRET=81b6d22b-4b39-4f79-b30b-01b477ce0d3e
# Get an access token
export TKN=`curl -XPOST "${KEYCLOAK_URL}/realms/${REALM}/protocol/openid-connect/token" \
    -H "Content-Type: application/x-www-form-urlencoded" \
    -d "grant_type=client_credentials" \
    -d "client_id=${SAMPLE_CLIENT_ID}" \
    -d "client_secret=${SAMPLE_CLIENT_SECRET}" |jq -r .access_token`
echo "access token: ${TKN}"
# Use an access token
curl -XGET \
    "${KEYCLOAK_URL}/realms/${REALM}/protocol/openid-connect/userinfo" \
    -H "Accept: application/json" \
    -H "Authorization: Bearer ${TKN}" |jq -r
# Revoke an access token
curl -i -XPOST \
    "${KEYCLOAK_URL}/realms/${REALM}/protocol/openid-connect/revoke" \
    -d "client_secret=${SAMPLE_CLIENT_SECRET}" \
    -d "token=${TKN}" \
    -d "token_type_hint=access_token"
# Try to use the revoked access token
curl -XGET \
and here is the script output:
./sample-rest-calls.zsh
access token: eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICI0NHNtUjZaZlkyVXV0WDlLMUw4em02Vi1YUHRnTlpET2FiTVRoNEFoT3h3In0.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.jyDM6CVmJn9rIT8ZlrVX03kCJNGolMJHeYHle8T61PQB4s0UrnyOnpiP8eRAhXE6wJh6bFyhcv5EgtTPNVK07vmEtkYY__YXlPJovYW2p4KassntnxWD1GbantVlIS3_F3ca032LX4r3OgxKp9fgaLSx4uVHaf_ZAYcLmtrQ7vDRo8RsAEunoUt840KeQKFRayie7NQZcscT5_wCzHK1tSFKK3b4axcslxRaXUlpxtxwxQsMVRlBL_1Ft4e7YTmakhjnvr4oKjwaX36RZJIOF6rXX00HGbb7BLrwFVprh-Vsnp2z0KjcJTYSpfwG5KWnGkSVuUzFeygwGUj6eA1Szg
  "sub": "79f07bb2-280c-4f68-9eee-139e74786f15",
  "email_verified": false,
  "preferred_username": "service-account-sample-m2m-client"
HTTP/1.1 100 Continue
Content-Length: 0
HTTP/1.1 200 OK
X-XSS-Protection: 1; mode=block
X-Frame-Options: SAMEORIGIN
Referrer-Policy: no-referrer
Content-Security-Policy: frame-src 'self'; frame-ancestors 'self'; object-src 'none';
Date: Fri, 11 Jun 2021 05:44:20 GMT
Connection: keep-alive
X-Robots-Tag: none
Strict-Transport-Security: max-age=31536000; includeSubDomains
X-Content-Type-Options: nosniff
Content-Length: 0
After the token is expired i get the standard error message from the /userinfo endpoint:
  "error": "invalid_token",
  "error_description": "Token verification failed"
Best regards,
Hermann
I have tried the same using the Postman, I got success. The token stays invalid after I revoked it.
Then I am trying to access user info API and getting 401.
