Not Exist ClassDescriptors
I implemented clustered cache by using JDBC_PING. Everything works fine for clustered cache. But when I go to Session tab on keycloak web page it returns 500 internal error. I reviewed keycloak logs. There are following:
ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-6) Uncaught server error: java.util.concurrent.CompletionException: org.infinispan.commons.CacheException: java.lang.NoClassDefFoundError: >
        at org.infinispan.util.concurrent.CompletionStages.join(CompletionStages.java:85)
        at org.infinispan.stream.impl.AbstractCacheStream.performPublisherOperation(AbstractCacheStream.java:207)
        at org.infinispan.stream.impl.DistributedCacheStream.collect(DistributedCacheStream.java:285)
        at org.infinispan.util.AbstractDelegatingCacheStream.collect(AbstractDelegatingCacheStream.java:280)
        at org.keycloak.models.sessions.infinispan.InfinispanUserSessionProvider.getActiveClientSessionStats(InfinispanUserSessionProvider.java:547)
        at org.keycloak.services.resources.admin.RealmAdminResource.getClientSessionStats(RealmAdminResource.java:630)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
        at java.base/java.lang.reflect.Method.invoke(Method.java:568)
        at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
        at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
        at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)
        at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
        at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
        at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
        at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
        at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
        at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:564)
        at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: org.infinispan.commons.CacheException: java.lang.NoClassDefFoundError: Could not initialize class org.jboss.marshalling.river.ClassDescriptors
        at org.infinispan.marshall.exts.ThrowableExternalizer.readObject(ThrowableExternalizer.java:181)
        at org.infinispan.marshall.exts.ThrowableExternalizer.readObject(ThrowableExternalizer.java:42)
        at org.infinispan.marshall.core.GlobalMarshaller.readWithExternalizer(GlobalMarshaller.java:727)
        at org.infinispan.marshall.core.GlobalMarshaller.readNonNullableObject(GlobalMarshaller.java:708)
        at org.infinispan.marshall.core.GlobalMarshaller.readNullableObject(GlobalMarshaller.java:357)
        at org.infinispan.marshall.core.BytesObjectInput.readObject(BytesObjectInput.java:32)
        at org.infinispan.remoting.responses.ExceptionResponse$Externalizer.readObject(ExceptionResponse.java:49)
        at org.infinispan.remoting.responses.ExceptionResponse$Externalizer.readObject(ExceptionResponse.java:41)
        at org.infinispan.marshall.core.GlobalMarshaller.objectFromObjectInput(GlobalMarshaller.java:191)
        at org.infinispan.marshall.core.GlobalMarshaller.objectFromByteBuffer(GlobalMarshaller.java:220)
        at org.infinispan.remoting.transport.jgroups.JGroupsTransport.processResponse(JGroupsTransport.java:1488)
        at org.infinispan.remoting.transport.jgroups.JGroupsTransport.processMessage(JGroupsTransport.java:1398)
        at org.infinispan.remoting.transport.jgroups.JGroupsTransport.access$300(JGroupsTransport.java:146)
        at org.infinispan.remoting.transport.jgroups.JGroupsTransport$ChannelCallbacks.up(JGroupsTransport.java:1586)
        at org.jgroups.JChannel.up(JChannel.java:780)
        at org.jgroups.stack.ProtocolStack.up(ProtocolStack.java:913)
        at org.jgroups.protocols.FRAG3.up(FRAG3.java:165)
        at org.jgroups.protocols.FlowControl.up(FlowControl.java:347)
        at org.jgroups.protocols.pbcast.GMS.up(GMS.java:876)
        at org.jgroups.protocols.pbcast.STABLE.up(STABLE.java:254)
        at org.jgroups.protocols.UNICAST3.deliverMessage(UNICAST3.java:1048)
        at org.jgroups.protocols.UNICAST3.addMessage(UNICAST3.java:771)
        at org.jgroups.protocols.UNICAST3.handleDataReceived(UNICAST3.java:752)
        at org.jgroups.protocols.UNICAST3.up(UNICAST3.java:405)
        at org.jgroups.protocols.pbcast.NAKACK2.up(NAKACK2.java:592)
        at org.jgroups.protocols.VERIFY_SUSPECT.up(VERIFY_SUSPECT.java:132)
        at org.jgroups.protocols.FailureDetection.up(FailureDetection.java:186)
        at org.jgroups.protocols.FD_SOCK.up(FD_SOCK.java:254)
        at org.jgroups.protocols.MERGE3.up(MERGE3.java:281)
        at org.jgroups.protocols.Discovery.up(Discovery.java:300)
        at org.jgroups.protocols.TP.passMessageUp(TP.java:1400)
        at org.jgroups.util.SubmitToThreadPool$SingleMessageHandler.run(SubmitToThreadPool.java:98)
        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
        ... 1 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.jboss.marshalling.river.ClassDescriptors
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77)
        at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)
        at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:480)
        at org.infinispan.marshall.exts.ThrowableExternalizer.readGenericThrowable(ThrowableExternalizer.java:282)
        at org.infinispan.marshall.exts.ThrowableExternalizer.readObject(ThrowableExternalizer.java:259)
I think, marshalling dependecies is not built. So it cannot be reached its classes.
I’m still get the error. can anyone help me?
You may need to try a lower version of JDK, such as 11.
you must be hero :slight_smile: It works
