Hello, I would like to overload FreeMarkerAccountProvider, I already did it without problem for login and email but this time my provider does not appear in server info.
Is it possible to overload it ?
Kévin
Kévin
How are you installing it? I believe you have to use the account
SPI name. E.g.:
<spi name="account">
<default-provider>my-freemarker</default-provider>
<provider name="my-freemarker" enabled="true"/>
</spi>
Yes I activate my provider with a startup script like this :
embed-server --std-out=echo --server-config=standalone-ha.xmlembed-server --std-out=echo --server-config=standalone-ha.xml
/subsystem=keycloak-server/spi=account:add()
/subsystem=keycloak-server/spi=account/provider=freemarker:add(enabled="false")
/subsystem=keycloak-server/spi=account/provider=freemarkeraccount:add(enabled="true")
stop-embedded-server
And in my CustomFreeMarkerAccountProviderFactory :
public class CustomFreeMarkerAccountProviderFactory extends FreeMarkerAccountProviderFactory{
private FreeMarkerUtil freeMarker;
@Override
public AccountProvider create(KeycloakSession session) {
return new CustomFreeMarkerAccountProvider(session, freeMarker);
@Override
public void init(Config.Scope config) {
freeMarker = new FreeMarkerUtil();
@Override
public String getId() {
return "freemarkeraccount";
But it doesn’t appear )=
Looks right. Might have something to do with the fact that it’s not being set as default. I don’t know how to do that in a startup script, but you might try that.
Did you define your SPI in META-INF? If not you need to define it there as well.
In jboss-deployment-structure.xml? or MET-INF.services? In the jboss-deployment-structure.xml file, I have already declared another provider and I was not able to declare another one )=.
My file looks like this:
<jboss-deployment-structure>
<deployment>
<module-alias name="deployment.com.test.keycloak.FreeMakerLoginFormProvider"/>
<dependencies>
<module name="javax.ws.rs.api"/>
<module name="org.keycloak.keycloak-server-spi"/>
<module name="org.keycloak.keycloak-server-spi-private"/>
<module name="org.keycloak.keycloak-services"/>
</dependencies>
</deployment>
</jboss-deployment-structure>
How can I add CustomFreeMarkerAccountProviderFactory in this file? I already tried without success (bad structure).
yup in the MET-INF.services, not sure that you need to change deployment structure.
