We’re getting Page has expired page on Forget Password Flow after
submitting your username. Below are the steps that we are following:
On clicking “Forgot Password?” from Login screen
Redirects to “Forgot Your Password?” screen, where it accepts username and
allow to submit the form.
Shows “Page has expired” screen with two options:-
To restart the login process Click here .
To continue the login process Click here .
Please advise, what is wrong with our Keycloak configuration.
The problem I believe is the user who would like to reset the password, double click the quick submit button. In the second request the token changes, thus giving the mentioned problem.
I solved the problem by blocking the submit button on the first request using javascript.
I rewrote the theme template in the file: login/login-reset-password.ftl
