Hi, I’ve got an issue with a token that on the face of it appears valid - has all the correct permissions, valid etc but i’m getting a 403 response and this warning is appearing in the keycloak logs.
I also get similar error like below. It seems that the user is locked. Because I didn’t change anything. Only thing I did making calls a lot of times. Keycloak version I’m using is : 14.0.0
