Possibility to set proxy in Keycloak
I am using Keycloak Docker image behind a corporate proxy. When i try to contact azure ad i get the connection refused. Outside the docker image on host the connection is working with adjusted corporate proxy. Is there a possiblity to set this proxy in keycloak although?
This is not a Keycloak issue, you have to configure your Docker environment properly that the containers are able to use the proxy connection. Use e.g. docker proxy - Google Search
