Hi everyone,
we run Keycloak 8.0.0 in combination with Postgres 12. Suddenly, after running for about one day, the log is flooded by error messages stating that the ResultSet cannot be extracted or the connection is closed.
Keycloak doesn’t recover from this situation and the only solution is to restart the application.
Any hints/ideas what we can do? Is upgrading to a more recent Keycloak version an option whcih might help?
Thanks a lot!
Oliver
16:37:25,219 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-1157) Uncaught server error: javax.persistence.PersistenceException: org.hibernate.exception.JDBCConnectionException: could not extract ResultSet
at org.hibernate@5.3.12.Final//org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:154)
at org.hibernate@5.3.12.Final//org.hibernate.query.internal.AbstractProducedQuery.list(AbstractProducedQuery.java:1515)
at org.hibernate@5.3.12.Final//org.hibernate.query.Query.getResultList(Query.java:132)
at org.keycloak.keycloak-model-jpa@8.0.0//org.keycloak.models.jpa.JpaUserCredentialStore.getStoredCredentialEntities(JpaUserCredentialStore.java:120)
at org.keycloak.keycloak-model-jpa@8.0.0//org.keycloak.models.jpa.JpaUserCredentialStore.getStoredCredentials(JpaUserCredentialStore.java:110)
at org.keycloak.keycloak-model-jpa@8.0.0//org.keycloak.models.jpa.JpaUserCredentialStore.getStoredCredentialsByType(JpaUserCredentialStore.java:125)
at org.keycloak.keycloak-model-jpa@8.0.0//org.keycloak.models.jpa.JpaUserProvider.getStoredCredentialsByType(JpaUserProvider.java:906)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.credential.UserCredentialStoreManager.getStoredCredentialsByType(UserCredentialStoreManager.java:90)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.credential.OTPCredentialProvider.isConfiguredFor(OTPCredentialProvider.java:93)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.credential.OTPCredentialProvider.isConfiguredFor(OTPCredentialProvider.java:97)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.authenticators.directgrant.ValidateOTP.configuredFor(ValidateOTP.java:96)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.authenticators.conditional.ConditionalUserConfiguredAuthenticator.isConfiguredFor(ConditionalUserConfiguredAuthenticator.java:65)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.authenticators.conditional.ConditionalUserConfiguredAuthenticator.lambda$matchConditionInFlow$1(ConditionalUserConfiguredAuthenticator.java:52)
at java.base/java.util.stream.MatchOps$1MatchSink.accept(MatchOps.java:90)
at java.base/java.util.ArrayList$ArrayListSpliterator.tryAdvance(ArrayList.java:1631)
at java.base/java.util.stream.ReferencePipeline.forEachWithCancel(ReferencePipeline.java:127)
at java.base/java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:502)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:488)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.MatchOps$MatchOp.evaluateSequential(MatchOps.java:230)
at java.base/java.util.stream.MatchOps$MatchOp.evaluateSequential(MatchOps.java:196)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.allMatch(ReferencePipeline.java:533)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.authenticators.conditional.ConditionalUserConfiguredAuthenticator.matchConditionInFlow(ConditionalUserConfiguredAuthenticator.java:52)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.authenticators.conditional.ConditionalUserConfiguredAuthenticator.matchCondition(ConditionalUserConfiguredAuthenticator.java:19)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.DefaultAuthenticationFlow.conditionalNotMatched(DefaultAuthenticationFlow.java:376)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.DefaultAuthenticationFlow.lambda$isConditionalSubflowDisabled$3(DefaultAuthenticationFlow.java:356)
at java.base/java.util.stream.ReferencePipeline.anyMatch(ReferencePipeline.java:528)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.DefaultAuthenticationFlow.isConditionalSubflowDisabled(DefaultAuthenticationFlow.java:356)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.DefaultAuthenticationFlow.processFlow(DefaultAuthenticationFlow.java:301)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.authentication.AuthenticationProcessor.authenticateOnly(AuthenticationProcessor.java:998)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.resourceOwnerPasswordCredentialsGrant(TokenEndpoint.java:589)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.processGrantRequest(TokenEndpoint.java:190)
at jdk.internal.reflect.GeneratedMethodAccessor648.invoke(Unknown Source)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:517)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:406)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:370)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:356)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:372)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:344)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:137)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:106)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:132)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:100)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:227)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.resteasy-jaxrs@3.9.0.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.keycloak-services@8.0.0//org.keycloak.services.filters.KeycloakSessionServletFilter.doFilter(KeycloakSessionServletFilter.java:91)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow@18.0.0.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.core@2.0.26.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.0.26.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.0.26.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.core@2.0.26.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.core@2.0.26.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow@18.0.0.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@18.0.0.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@18.0.0.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@18.0.0.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1504)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.26.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.core@2.0.26.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:376)
at io.undertow.core@2.0.26.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
Caused by: org.hibernate.exception.JDBCConnectionException: could not extract ResultSet
at org.hibernate@5.3.12.Final//org.hibernate.exception.internal.SQLStateConversionDelegate.convert(SQLStateConversionDelegate.java:115)
at org.hibernate@5.3.12.Final//org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:42)
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:113)
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:99)
at org.hibernate@5.3.12.Final//org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.extract(ResultSetReturnImpl.java:69)
at org.hibernate@5.3.12.Final//org.hibernate.loader.Loader.getResultSet(Loader.java:2265)
at org.hibernate@5.3.12.Final//org.hibernate.loader.Loader.executeQueryStatement(Loader.java:2028)
at org.hibernate@5.3.12.Final//org.hibernate.loader.Loader.executeQueryStatement(Loader.java:1990) (cut off, too long...)
