Problem getting federated user after login in Eidas-SAML2 | KC 15.0.2
Hello! I’ve been working in connect our Keycloak to one Eidas-Saml2 system. The petition goes well, and returns to my endpoint in keycloak. Then with all received data formatted the petition goes to IdentityBrokerService.authenticated method.
In there, when Keycloak get the federatedUser never pases through my CustomUserProvider so never finds it and always go to “firstLoginBroker”. I tried to configure this AutheticatorFlow, but again never gets my CustomUserProvider and fails:
WARN org.keycloak.services KC-SERVICES0013: Failed authentication
org.keycloak.authentication.AuthenticationFlowException: null
at org.keycloak.authentication.AuthenticationProcessor.authenticateOnly(AuthenticationProcessor.java:993) ~[keycloak-services-15.0.2.jar:15.0.2]
at org.keycloak.services.resources.LoginActionsService$1.authenticateOnly(LoginActionsService.java:799) ~[keycloak-services-15.0.2.jar:15.0.2]
I revised all the process and i see that in order to get the federated user first it tries to check the cache (UserCacheSession). As the cache is null goes to check the delegate “UserStorageManager” and gets a new instance of it from the session (DefaultKeycloakSession).
public UserStorageManager(KeycloakSession session) {
super(session, UserStorageProviderFactory.class, UserStorageProvider.class,
UserStorageProviderModel::new, “user”);
I don’t know how to set my CustomUserProviderFactory in order to continue and finish.
Thanks in advanced
Hi
After many hours i finally resolved this. Maybe someone in the future ends here with the same problem, so i will try to help you my fellow friend.
The normal behaviour of Keycloak is to check first the cache and then try to do a “First login flow”. You can create your own flow with your own Authenticator and do whatever you need. The second time Keycloak will get the data from the cache.
So check for an authenticator, get your own flow and use it in your Saml. Even in the Saml form you can add your new flow.
I hope this helps, good luck.
