I am using angular 11 with keycloak version 12.0.2.
I have a single realm which has multiple clients and i want to implement a feature explained below.
I login with one clientid
once logged in user will get list of application in dropdown.
Once user select any application i want to fetch token for that application so that i can load data related to that.
So to fetch the token when user selects any app, i am using below method and passing the proper client id but it is not authorising the client.
this.keycloakConfig.clientId = selected client id
this.keycloakAuth = Keycloak(this.keycloakConfig);|this.keycloakAuth .init({ config: this.keycloakConfig }, { checkLoginIframe: false, }) .then(() => {})
Is there any method to have seamless sso in keycloak.
