@xkey
Not sure how to fix your issue, but I have succeeded in using MySQL. My documents for this is really long so Im going to giving you the MySQL configurations I have. You may have to adjust these steps for your needs.
Install mysql java connector
cd /opt/
wget https://dev.mysql.com/get/Downloads/Connector-J/mysql-connector-java-5.1.47.zip
unzip mysql-connector-java-5.1.47.zip
Configure database
mysql -u root -p
CREATE DATABASE keycloak CHARACTER SET utf8 COLLATE utf8_unicode_ci;
GRANT ALL PRIVILEGES ON keycloak.* TO 'keycloak'@'localhost' identified by 'Password1';
FLUSH privileges;
exit;
These missing steps here was: Enable and start MySQL, Create a keycloak user, Download keycloak, Create keycloak as a service.
Configure wildfly
./bin/jboss-cli.sh
module add --name=org.mysql --dependencies=javax.api,javax.transaction.api --resources=/opt/mysql-connector-java-5.1.47/mysql-connector-java-5.1.47.jar
exit
./bin/jboss-cli.sh 'embed-server,/subsystem=datasources/jdbc-driver=org.mysql:add(driver-name=org.mysql,driver-module-name=org.mysql,driver-class-name=com.mysql.jdbc.Driver)'
./bin/jboss-cli.sh 'embed-server,/subsystem=datasources/data-source=KeycloakDS:remove'
./bin/jboss-cli.sh 'embed-server,/subsystem=datasources/data-source=KeycloakDS:add(driver-name=org.mysql,enabled=true,use-java-context=true,connection-url="jdbc:mysql://localhost:3306/keycloak?useSSL=false&useLegacyDatetimeCode=false&serverTimezone=Europe/Budapest&characterEncoding=UTF-8",jndi-name="java:/jboss/datasources/KeycloakDS",user-name=keycloak,password="Password1",valid-connection-checker-class-name=org.jboss.jca.adapters.jdbc.extensions.mysql.MySQLValidConnectionChecker,validate-on-match=true,exception-sorter-class-name=org.jboss.jca.adapters.jdbc.extensions.mysql.MySQLValidConnectionChecker)'
./bin/add-user-keycloak.sh -u admin -p Password1 -r master
Create Directory for MySQL Java Connector
mkdir -p /opt/keycloak/modules/system/layers/keycloak/com/mysql/main
cd /opt/keycloak/modules/system/layers/keycloak/com/mysql/main
cp /opt/mysql-connector-java-5.1.47/mysql-connector-java-5.1.47-bin.jar .
Create module XML file
touch module.xml
<?xml version="1.0" ?>
<module xmlns="urn:jboss:module:1.3" name="com.mysql">
<resources>
<resource-root path="mysql-connector-java-5.1.47-bin.jar" />
</resources>
<dependencies>
<module name="javax.api"/>
<module name="javax.transaction.api"/>
</dependencies>
</module>
Hope that helps
