(I have another topic addressing this issue however this is more detailed and I will flag the other entry for removal)
PLEASE note that the URLs mentioned below should be preceded with “http://” but I wasn’t allowed to post this if they were included!
Hi!
I want to use Keycloak as a standard way of authenticating users to applications running in our Kubernetes clusters. One of the clusters is running the Elastic ECK component (v1.1.1) and we use the operator to deploy Elastic clusters and Kibana as a frontend. In order to keep things as simple as possible I’ve done the following.
Deployed Kibana
apiVersion: kibana.k8s.elastic.co/v1
kind: Kibana
metadata:
name: {{ .Values.kibana.name }}
namespace: {{ .Release.Namespace }}
annotations:
traefik.ingress.kubernetes.io/service.sticky.cookie: "true"
spec:
version: {{ .Values.kibana.version }}
count: {{ .Values.kibana.instances }}
elasticsearchRef:
name: {{ .Values.kibana.elasticCluster }}
podTemplate:
spec:
containers:
- name: kibana
env:
- name: SERVER_BASEPATH
value: {{ .Values.kibana.serverBasePath }}
resources:
requests:
{{- if not .Values.kibana.cpu.enableBurstableQoS }}
cpu: {{ .Values.kibana.cpu.requests }}
{{- end }}
memory: {{ .Values.kibana.memory.requests }}Gi
limits:
cpu: {{ .Values.kibana.cpu.limits }}
{{- end }}
memory: {{ .Values.kibana.memory.limits }}Gi
http:
tls:
selfSignedCertificate:
disabled: true
Created Ingress
apiVersion: traefik.containo.us/v1alpha1
kind: Middleware
metadata:
name: kibana-{{ .Values.kibana.name }}-stripprefix
spec:
stripPrefix:
prefixes:
- {{ .Values.kibana.serverBasePath }}
forceSlash: true
apiVersion: networking.k8s.io/v1beta1
kind: Ingress
metadata:
name: {{ .Values.kibana.name }}-ingress
annotations:
kubernetes.io/ingress.class: traefik
traefik.ingress.kubernetes.io/router.entrypoints: http
traefik.ingress.kubernetes.io/router.middlewares: {{ .Release.Namespace }}-kibana-{{ .Values.kibana.name }}-stripprefix@kubernetescrd
spec:
rules:
- http:
paths:
- path: {{ .Values.kibana.serverBasePath }}
backend:
servicePort: {{ .Values.kibana.port }}
serviceName: {{ .Values.kibana.name }}-kb-http
Result
Deploying the above works perfectly fine. I’m able to reach the Kibana UI using the external IP exposed by our MetalLB component. I simply enter “external IP/service/logging/kibana” and I’m presented to the Kibana log in screen and I can log on using the “built in” authentication process.
Adding the Keycloak Gatekeeper
Now, if I add the following to the Kibana manifest, effectively adding the Keycloak Gatekeeper sidecar to the Kibana Pod:
- name: {{ .Values.kibana.name }}-gatekeeper
image: "{{ .Values.kibana.keycloak.gatekeeper.repository }}/docker-r/keycloak/keycloak-gatekeeper:{{ .Values.kibana.keycloak.gatekeeper.version }}"
args:
- --config=/etc/keycloak-gatekeeper.conf
ports:
- containerPort: 3000
volumeMounts:
- name: gatekeeper-config
mountPath: /etc/keycloak-gatekeeper.conf
subPath: keycloak-gatekeeper.conf
volumes:
configMap:
name: {{ .Release.Name }}-gatekeeper-config
with the following ConfigMap which is “mounted”:
apiVersion: v1
kind: ConfigMap
metadata:
data:
keycloak-gatekeeper.conf: |+
redirection-url: {{ .Values.kibana.keycloak.gatekeeper.redirectionUrl }}
discovery-url: "https://.../auth/realms/{{ .Values.kibana.keycloak.gatekeeper.realm }}"
skip-openid-provider-tls-verify: true
client-id: kibana
client-secret: {{ .Values.kibana.keycloak.gatekeeper.clientSecret }}
enable-refresh-tokens: true
encryption-key: ...
listen: :3000
tls-cert:
tls-private-key:
secure-cookie: false
upstream-url: {{ .Values.kibana.keycloak.gatekeeper.upstreamUrl }}
resources:
- uri: /*
groups:
- kibana
The upstream-url points to “127.0.0.1:5601”
and add an intermediary service:
In order to explicitly address the Gatekeeper proxy I added another service, “keycloak-proxy” as such:
apiVersion: v1
kind: Service
metadata:
name: {{ .Values.kibana.name }}-keycloak-proxy
spec:
type: ClusterIP
selector:
common.k8s.elastic.co/type: kibana
kibana.k8s.elastic.co/name: cap-logging
ports:
- name: http
protocol: TCP
port: 8888
targetPort: proxyport
and change the backend definition in the Kibana definition to:
servicePort: 8888
serviceName: {{ .Values.kibana.name }}-keycloak-proxy
and then issue the same URL as above, “external IP/service/logging/kibana”, I’m redirected to “external IP/oauth/authorize?state=0db97b79-b980-4cdc-adbe-707a5e37df1b” and get an “404 Page not found” error.
If I reconfigure the “keycloak-proxy” service and convert it into a NodePort and expose it on, say, port 32767 and issue an “host IP:32767” I’m presented to the Keycloak login screen on the Keycloak server!
If I look into the Gatekeeper startup log I find the following:
1.6018108005048046e+09 info starting the service {"prog": "keycloak-gatekeeper", "author": "Keycloak", "version": "7.0.0 (git+sha: f66e137, built: 03-09-2019)"}
1.6018108005051787e+09 info attempting to retrieve configuration discovery url {"url": "https://.../auth/realms/...", "timeout": "30s"}
1.601810800537417e+09 info successfully retrieved openid configuration from the discovery
1.6018108005392597e+09 info enabled reverse proxy mode, upstream url {"url": "http://127.0.0.1:5601"}
1.6018108005393562e+09 info using session cookies only for access and refresh tokens
1.6018108005393682e+09 info protecting resource {"resource": "uri: /*, methods: DELETE,GET,HEAD,OPTIONS,PATCH,POST,PUT,TRACE, required: authentication only"}
1.6018108005398147e+09 info keycloak proxy service starting {"interface": ":3000"}
This is what I get when I try to access Kibana through the Gatekeeper proxy:
"host/service/logging/kibana" (gets redirected to) "host/oauth/authorize?state=4dbde9e7-674c-4593-83f2-a8e5ba7cf6b5"
and the Gatekeeper log:
1.601810963344485e+09 error no session found in request, redirecting for authorization {"error": "authentication session not found"}
I’ve been struggling with this for some time now and seems to be stuck! If anybody here “knows what’s going on” I’d be very grateful.
