I am attempting to install 15.0.2 in minikube. Everything loads fine (minikube), but the container fails to start as I get the following issue which I can not get past:
Namespace: default
Priority: 0
Node: keycloke.devXX.domain.org/XXX.XXX.XXX.XXX
Start Time: Tue, 08 Feb 2022 09:30:36 -0800
Labels: app=keycloak
pod-template-hash=8556878c5b
Annotations: <none>
Status: Running
IP: XXX.XXX.XXX.XXX
IPs:
IP: XXX.XXX.XXX.XXX
Controlled By: ReplicaSet/keycloak-8556878c5b
Containers:
keycloak:
Container ID: docker://839fe523ada2711e79f3b707058bf5f9e9a802bfcad282b66c97d937470248fc
Image: quay.io/keycloak/keycloak:15.0.2
Image ID: docker-pullable://quay.io/keycloak/keycloak@sha256:64fb81886fde61dee55091e6033481fa5ccdac62ae30a4fd29b54eb5e97df6a9
Ports: 8080/TCP, 8443/TCP
Host Ports: 0/TCP, 0/TCP
State: Running
Started: Tue, 08 Feb 2022 09:32:30 -0800
Last State: Terminated
Reason: Error
Exit Code: 1
Started: Tue, 08 Feb 2022 09:31:38 -0800
Finished: Tue, 08 Feb 2022 09:32:00 -0800
Ready: False
Restart Count: 3
Readiness: http-get http://:8080/auth/realms/master delay=0s timeout=1s period=10s #success=1 #failure=3
Environment:
DB_VENDOR: POSTGRES
DB_ADDR: XXX.XXX.XXX.XXX
DB_DATABASE: keycloak
DB_USER: KEYCLOAK_USER
DB_PASSWORD: KEYCLOAK_PASSWORD
KEYCLOAK_USER: KEYCLOAK_USER
KEYCLOAK_PASSWORD: KEYCLOAK_PASSWORD
PROXY_ADDRESS_FORWARDING: false
Mounts:
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-642c8 (ro)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
kube-api-access-642c8:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
QoS Class: BestEffort
Node-Selectors: <none>
Tolerations: node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
Type Reason Age From Message
Normal Scheduled 2m4s default-scheduler Successfully assigned default/keycloak-8556878c5b-bq6w6 to keycloke.dev30.apollo.e911.io
Normal Pulled 62s (x3 over 2m3s) kubelet Container image "quay.io/keycloak/keycloak:15.0.2" already present on machine
Normal Created 62s (x3 over 2m3s) kubelet Created container keycloak
Normal Started 62s (x3 over 2m3s) kubelet Started container keycloak
Warning Unhealthy 54s (x11 over 2m2s) kubelet Readiness probe failed: Get "http://XXX.XXX.XXX.XXX:8080/auth/realms/master": dial tcp XXX.XXX.XXX.XXX:8080: connect: connection refused
Warning Unhealthy 43s (x2 over 103s) kubelet Readiness probe failed: Get "http://XXX.XXX.XXX.XXX:8080/auth/realms/master": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
Warning BackOff 24s (x3 over 74s) kubelet Back-off restarting failed container
My deployment.yaml file is this:
apiVersion: v1
kind: Service
metadata:
labels:
app: keycloak
spec:
ports:
- name: http
port: 8080
targetPort: 8080
selector:
app: keycloak
type: LoadBalancer
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: default
labels:
app: keycloak
spec:
replicas: 1
selector:
matchLabels:
app: keycloak
template:
metadata:
labels:
app: keycloak
spec:
containers:
- name: keycloak
image: quay.io/keycloak/keycloak:15.0.2
env:
- name: DB_VENDOR
value: POSTGRES
- name: DB_ADDR
value: XXX.XXX.XXX.XXX
- name: DB_DATABASE
value: KEYCLOAK_USER
- name: DB_USER
value: KEYCLOAK_PASSWORD
- name: DB_PASSWORD
- name: KEYCLOAK_USER
value: "KEYCLOAK_USER"
- name: KEYCLOAK_PASSWORD
value: "KEYCLOAK_PASSWORD"
value: "false"
ports:
- name: http
containerPort: 8080
- name: https
containerPort: 8443
readinessProbe:
httpGet:
path: /auth/realms/master
port: 8080
Based on all documentation I could find, I am doing everything right. Help is greatly appreciated!
