Is there a way to remove Keycloak’s built-in themes so they are not available for selection in the “Realm Settings”->“Themes” tab? I have a few custom themes available, that are acceptable for branding purposes, but I don’t want the admin to be able to choose base or keycloak themes.
did you try removing them from the folder $KEYCLOAK_HOME/themes ?
Or maybe changing the dir in standalone(-ha).xml for the theme section to an empty folder. This last one could be more upgrade-friendly.
That said, if your custom themes use the base theme (eg, for message resources), it will not work.
