I’ve been testing a local installation of keycloak a long time ago. Now that I want to login back into the admin console I’m unable to do so. It looks like I forgot the username/password.
Is there a way for me to reset the admin/password to a default one, by using for example the CLI or some tool running on the server?
Yes you can do it using the CLI using the add-user-keycloak.sh script as follows: sudo -u keycloak ./bin/add-user-keycloak.sh --user YourUser --password YourNewPass --realm YourRealm
You will add a user and you can later remove the old user.
When im trying above command it was failing and getting below output
root@ip-192-168-23-158:/opt/keycloak/bin# sudo -u ubuntu ./add-user-keycloak.sh --user admin --password Starlet@2hjhjk --realm Dev
No content to map due to end-of-input
at [Source: (FileInputStream); line: 1, column: 0]
please be kind enough to check what is missing out there
