Under the Reset Credentials flow I can disable the forcing of a user to set the OTP by setting the Reset OTP to disable. But when the user resets their password they are not required to use OTP for this session, and they are logged right in. Is there a way to force a new login after the password has been rest instead of auto-login after rest?
