Hello everyone
We are experiencing something (I think) weird and we need to know how to solve this with Keycloak.
We have an application which stores the refresh token for users. These are offline tokens.
When one of these users resets his password, the refresh token stored into our application is still valid and still issues new access tokens, despite of the fact that the password has been reset.
Is it a security hole? If someone stoles the refresh token, he can still obtain the access token despite the reset of the password.
How can the user behave if he feels that his password (and refresh token) has been stolen?
Is there any Keycloak configuration to mitigate (or resolve) this problem?
Also if you enable the option Revoke refresh tokens , then each offline token can be used just once. So after refresh, you always need to store the new offline token from refresh response into your DB instead of the previous one.
If you use that option, then it will mitigate the use of old offline access tokens, because they will be invalidated every time you do a refresh.
@xgp As for the revoke, I can’t figure how it could solve my problem: if the user who stole my refresh token uses it to obtain new couple access-refresh token, he could use every refresh token only once but every time he can obtain a new one; so the problem remains.
@mbonn So there is no way to trigger this after a password reset?
Correct, assuming the attacker uses the refresh token before the user does, he could do so indefinitely.
To trigger on a password reset, you can write a custom EventListenerProvider that listens for the UPDATE_PASSWORD event and then invalidates all the user’s refresh tokens.
thanks for your answer The post you linked me, unfortunately, indicated to call a REST API as a Keycloak admin.
My problem is that I am inside an event listener, so it have not access to admin credentials.
Earlier in this topic you indicated me this instruction: keycloakSession.users().revokeConsentForClient(realm, userId, clientInternalId);, but it seems that does not work
Also if I call keycloakSession.users().getConsents() on the user, is returned an empty list, but in the User -> Consents tab I can see the offline token consent for that user.
