Hi all,
I have been tasked with deploying KC on-prem for a client. The OS is RHEL 8.4 and Docker/podman is not permitted (much to my chagrin), therefore I am doing an old-school deployment directly on the box.
When trying to boot up KC on the RHEL server, it crashes with the following stacktrace:
17:11:00,204 FATAL [org.keycloak.services] (ServerService Thread Pool -- 58) Error during startup: org.keycloak.component.ComponentValidationException: Failed to generate keys
at org.keycloak.keycloak-services@15.0.2//org.keycloak.keys.GeneratedRsaKeyProviderFactory.generateKeys(GeneratedRsaKeyProviderFactory.java:123)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.keys.GeneratedRsaKeyProviderFactory.validateConfiguration(GeneratedRsaKeyProviderFactory.java:103)
at org.keycloak.keycloak-model-jpa@15.0.2//org.keycloak.models.jpa.RealmAdapter.importComponentModel(RealmAdapter.java:2020)
at org.keycloak.keycloak-model-jpa@15.0.2//org.keycloak.models.jpa.RealmAdapter.addComponentModel(RealmAdapter.java:2000)
at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.models.utils.DefaultKeyProviders.createRsaKeyProvider(DefaultKeyProviders.java:56)
at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.models.utils.DefaultKeyProviders.createProviders(DefaultKeyProviders.java:36)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.managers.ApplianceBootstrap.createMasterRealm(ApplianceBootstrap.java:90)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication$3.run(KeycloakApplication.java:201)
at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:250)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication.bootstrap(KeycloakApplication.java:172)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:136)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:128)
at org.keycloak.keycloak-wildfly-extensions@15.0.2//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:36)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:114)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2835)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:376)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:288)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:98)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:140)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:588)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:559)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:601)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
Caused by: org.keycloak.common.util.PemException: org.bouncycastle.util.io.pem.PemGenerationException: unknown object passed - can't encode.
at org.keycloak.keycloak-common@15.0.2//org.keycloak.common.util.PemUtils.encode(PemUtils.java:141)
at org.keycloak.keycloak-common@15.0.2//org.keycloak.common.util.PemUtils.encodeKey(PemUtils.java:114)
at org.keycloak.keycloak-services@15.0.2//org.keycloak.keys.GeneratedRsaKeyProviderFactory.generateKeys(GeneratedRsaKeyProviderFactory.java:121)
... 50 more
Caused by: org.bouncycastle.util.io.pem.PemGenerationException: unknown object passed - can't encode.
at org.bouncycastle.bcpkix@1.68.00.0//org.bouncycastle.openssl.MiscPEMGenerator.createPemObject(Unknown Source)
at org.bouncycastle.bcpkix@1.68.00.0//org.bouncycastle.openssl.MiscPEMGenerator.generate(Unknown Source)
at org.bouncycastle.bcprov@1.68.0//org.bouncycastle.util.io.pem.PemWriter.writeObject(Unknown Source)
at org.bouncycastle.bcpkix@1.68.00.0//org.bouncycastle.openssl.jcajce.JcaPEMWriter.writeObject(Unknown Source)
at org.keycloak.keycloak-common@15.0.2//org.keycloak.common.util.PemUtils.encode(PemUtils.java:135)
... 52 more
I have a hunch that it might be related to FIPS mode being enabled on this RHEL instance (also something that is a hard requirement of the client). I am going to try and replace the BouncyCastle jars with FIPS versions and see if that does anything but I also wanted to post here in case anyone can guide me in a better direction.
FYI, I have tried both Java 8 and 11 to the same effect. I’ve also tried it with a fresh, clean version of KC without any modifications.
Thanks!
