Hello!
I have keycloak configured to offer SAML2 auth endpoint for my Synology Directory Server. LDAP login is working fine and I’m able to successfully auth via SAML to a third party application, however when I try to logout from the third party application, I get a generic error in the web page and the below stack trace in KeyCloak. I’m almost certain that this error is indicating that something I should have configured must have been left null on accident, but I cannot locate what feature uriTemplate might be that I should configure. searching for this error on google doesn’t provide a lot of keycloak-specific info.
Thanks in advance for any help you can provide!
Error:
22:51:38,510 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-21) Uncaught server error: java.lang.RuntimeException: java.lang.IllegalArgumentException: uriTemplate parameter is null
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.SamlService$BindingProtocol.logoutRequest(SamlService.java:500)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.SamlService$BindingProtocol.handleSamlRequest(SamlService.java:269)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.SamlService$BindingProtocol.execute(SamlService.java:517)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.SamlService.redirectBinding(SamlService.java:604)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:526)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:415)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:376)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:356)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:378)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:347)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:227)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.resteasy-jaxrs@3.11.0.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.services.filters.KeycloakSessionServletFilter.doFilter(KeycloakSessionServletFilter.java:91)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow@19.0.0.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.core@2.0.30.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.0.30.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.0.30.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.core@2.0.30.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.core@2.0.30.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow@19.0.0.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@19.0.0.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@19.0.0.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@19.0.0.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1541)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.30.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.core@2.0.30.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:376)
at io.undertow.core@2.0.30.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
Caused by: java.lang.IllegalArgumentException: uriTemplate parameter is null
at org.keycloak.keycloak-common@10.0.0//org.keycloak.common.util.KeycloakUriBuilder.uriTemplate(KeycloakUriBuilder.java:132)
at org.keycloak.keycloak-common@10.0.0//org.keycloak.common.util.KeycloakUriBuilder.uri(KeycloakUriBuilder.java:190)
at org.keycloak.keycloak-common@10.0.0//org.keycloak.common.util.KeycloakUriBuilder.fromUri(KeycloakUriBuilder.java:52)
at org.keycloak.keycloak-saml-core@10.0.0//org.keycloak.saml.BaseSAML2BindingBuilder.generateRedirectUri(BaseSAML2BindingBuilder.java:358)
at org.keycloak.keycloak-saml-core@10.0.0//org.keycloak.saml.BaseSAML2BindingBuilder$BaseRedirectBindingBuilder.generateURI(BaseSAML2BindingBuilder.java:202)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.JaxrsSAML2BindingBuilder$RedirectBindingBuilder.response(JaxrsSAML2BindingBuilder.java:87)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.JaxrsSAML2BindingBuilder$RedirectBindingBuilder.response(JaxrsSAML2BindingBuilder.java:79)
at org.keycloak.keycloak-services@10.0.0//org.keycloak.protocol.saml.SamlService$BindingProtocol.logoutRequest(SamlService.java:497)
... 73 more
