SAML Validate Signatures
Hi
Can any one please help how to update IDP certificate in Identity provider SAML configuration.
I configured the “validate signature” and uploaded the “Validating X509 certificates” in SAML IDP configuration.
User get sign in successfully on IDP but when it redirected to keycloak getting below error.
2024-04-04 00:37:41,950 DEBUG [org.keycloak.events.jpa.JpaEventStoreProvider] (Timer-0) Cleared 0 expired events in all realms
2024-04-04 00:37:47,959 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-25) Uncaught server error: java.lang.RuntimeException: org.keycloak.saml.common.exceptions.ProcessingException: PL00102: Processing Exception:
	at org.keycloak.broker.saml.SAMLEndpoint$Binding.getIDPKeyLocator(SAMLEndpoint.java:264)
	at org.keycloak.broker.saml.SAMLEndpoint$PostBinding.verifySignature(SAMLEndpoint.java:716)
	at org.keycloak.broker.saml.SAMLEndpoint$Binding.handleSamlResponse(SAMLEndpoint.java:648)
	at org.keycloak.broker.saml.SAMLEndpoint$Binding.execute(SAMLEndpoint.java:276)
	at org.keycloak.broker.saml.SAMLEndpoint.postBinding(SAMLEndpoint.java:187)
	at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:90)
	at io.quarkus.vertx.core.runtime.VertxCoreRecorder$13.runWith(VertxCoreRecorder.java:545)
Caused by: org.keycloak.saml.common.exceptions.ProcessingException: PL00102: Processing Exception:
	at org.keycloak.saml.common.DefaultPicketLinkLogger.processingError(DefaultPicketLinkLogger.java:164)
	at org.keycloak.saml.processing.core.util.XMLSignatureUtil.getX509CertificateFromKeyInfoString(XMLSignatureUtil.java:592)
	at org.keycloak.broker.saml.SAMLEndpoint$Binding.getIDPKeyLocator(SAMLEndpoint.java:258)
	... 55 more
Caused by: java.security.cert.CertificateException: Could not parse certificate: java.io.IOException: Illegal footer: -----BEGINCERTIFICATE-----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-----ENDCERTIFICATE-----
	at java.base/sun.security.provider.X509Factory.engineGenerateCertificate(X509Factory.java:115)
	at java.base/java.security.cert.CertificateFactory.generateCertificate(CertificateFactory.java:355)
	at org.keycloak.saml.processing.core.util.XMLSignatureUtil.getX509CertificateFromKeyInfoString(XMLSignatureUtil.java:589)
	... 56 more
Caused by: java.io.IOException: Illegal footer: -----BEGINCERTIFICATE-----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-----ENDCERTIFICATE-----
	at java.base/sun.security.provider.X509Factory.checkHeaderFooter(X509Factory.java:661)
	at java.base/sun.security.provider.X509Factory.readOneBlock(X509Factory.java:643)
	at java.base/sun.security.provider.X509Factory.engineGenerateCertificate(X509Factory.java:99)
	... 58 more
I once successfully followed this guide to do just that with ADFS: How to Setup MS AD FS 3.0 as Brokered Identity Provider in Keycloak - Keycloak
I had the same problem, but it worked well with base64 encoded DER certificates, which you can get from PEM with openssl:
openssl x509 -in your-cert.pem -outform der | base64
have you tried removing “-----BEGINCERTIFICATE-----” and “-----ENDCERTIFICATE-----”? This worked for me.
