Hi everyone,
I´m using a keycloak instance to login in the frontend and secure the backend-api. After deployment on a linux machine on aws I faced a issue. I´m getting constantly redirected to the login page by accessing the api with a jwt token. Locally it´s working fine.
My client is a confidential client. I´m using client_id and _secret to authorize for the token call. The jwt token is valid and sucessfully generated.
My implementation of the api works with expressJs and the keycloak-nodejs-connector:
keycloakConfig = {
serverUrl: 'https://keycloak.myserver.com/auth',
realm: 'examplerealm',
clientId: 'ui-client'
public init() {
if (this.keycloak) {
console.warn("Trying to init Keycloak again!");
return this.keycloak;
else {
console.log("Initializing Keycloak...");
const memoryStore = new session.MemoryStore();
// @ts-ignore
this.keycloak = new Keycloak({ store: memoryStore }, this.keycloakConfig );
I could imagine that it is dependent on the current https setting. My nodejs api provides a endpoint for http and https (locally with a self signed certificate). On the server, where keycloak is running, I added a letsencrypt certificate with certbot and everything looks fine in the browser.
Keycloak is started with the docker-container jboss/keycloak.
I´m curious to figure out my current issue and help is very appreciated Let me know, if I missed to add necessary informations.
Thanks in advance.
Dominik
Edit:
I followed this medium article
