I was trying to figure out how to go straight to the “Select login method” page directly, rather than clicking on “Try another way”.
So far, I believe there is no way of doing that.
The only way I can imagine is, to extend the templates with some JavaScript and to look for the „try another way“ link and if available, „click“ the link by script…. yes, hacky
I thought about that, but I didn’t have the courage to say it… Then you can store some sort of flag in a cookie to avoid clicking next time. Just following dasniko’s idea, not mine!
I see two possible solutions:
Incorporate the list from the select-login-method page into a copy of login.ftl and overwrite the default login.ftl (you can do this with a login-theme
not the solution you really like, but at least you have the list on the first page
- if you really like to have the selelect-login-method as first page
Create a SPI-Extension (AuthenticatorForm) where you just show the selelect-login-method page.
Put that after Cookies in your browser-flow as required
→ only you need to do is to filter out your Authenticator from the list.
Both solutions I have already used and both are working fine
keycloak[ch]
can you please share the custom implementation that you did for option two
