Setting up Ingress using AWS NLB
I’ve currently deployed keycloak via helm chart and I’ve deployed an Nginx Ingress Controller which in turn is a Network Load Balancer in AWS. I didn’t change any of the default settings of the helm chart in regards to ports etc.
The Problem I’m having is I can reach keycloak using this NLB but when I try to access the Console I just get a blank page and nothing happens. I’m assuming It has to do with my Ingress resource which I will post an example of below. I’m assuming i’m missing some annotations or something, this is all relatively new to me so any help would be greatly appreciated. I can post other samples as needed. SSL is being terminated on the NLB itself.
Sample Ingress.yaml
apiVersion: networking.k8s.io/v1beta1
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/ssl-redirect: “true”
spec:
rules:
  • host: keycloak-new-prod.example.ca
    http:
    paths:
    • backend:
      serviceName: keycloak-http
      servicePort: 80
