I’m trying to integrate keycloak on a simple spring boot project but it seems like the security-constraints
aren’t working. When I make a request it just passes right through and no log is given.
Repo with the demo project: https://gitlab.com/wallysoncarvalho/keycloak-springboot-demo
On this repo, there’s an export JSON file of the realm I created to secure this API.
I’m using keycloak running on a docker container from an image of version 10.0.2
, I downgraded the deps from the project but the error persisted.
ivangfr
September 8, 2020, 6:15pm
2
I have 2 projects that use spring-boot and keycloak… Maybe, they can help as reference
The goal of this project is to create a simple Spring Boot REST API, called simple-service, and secure it with Keycloak. Furthermore, the API users will be loaded into Keycloak from OpenLDAP server...
Best
Thanks. But I see that you used spring-security, any special reason for that? Did you try writing the constraints on the application.yml?
ivangfr
September 8, 2020, 8:06pm
4
Hum, ok… I’ve seen now in your link…
keycloak.security-constraints
I’ve never tried it before. I will try whenever I have time.
hey @ivangfr , using spring security approach worked.
But i’m still bothered that the Sprint Boot Adapter didn’t !
