When I deploy my jar, my SPIs within it, do not get added. I can’t find them on the Server Info page on Keycloak’s dashboard, or anywhere else.
Except, I do see my jar added to the themeResources section of Server Info.
Due to this, I assumed there’s an issue with the Java SPIs I try to deploy within the same jar or the META-INF. The services in META-INF are all defined, so I suspect my jboss-deployment-structure.xml isn’t correct. I have bunch of maven dependencies that I use in my SPIs but I didn’t define those in the JBoss XML file.
Should all dependencies be defined there, or I should just keep the org.keycloak and org.jboss?
My jboss-deployment-structure.xml looks like this
<jboss-deployment-structure>
<deployment>
<dependencies>
<module name="org.keycloak.keycloak-core"/>
<module name="org.keycloak.keycloak-server-spi"/>
<module name="org.keycloak.keycloak-server-spi-private"/>
<module name="org.keycloak.keycloak-services"/>
<module name="org.keycloak.keycloak-saml-core-public"/>
<module name="org.jboss.logging"/>
</dependencies>
</deployment>
</jboss-deployment-structure>
