bilak
March 29, 2020, 2:23pm
1
I’m using spring boot 2.2.x + keycloak adapter 9.0.0.
I’m wondering whether it is possible to map keycloak client’s scope to spring security.
So for example if I want to use something like @PreAuthorize("hasAuthority('SCOPE_message:read')")
how can this be done with keycloak spring-boot adapter? Currently only user roles are mapped, client scopes are omitted.
I know how to do that without adapter using jwt token mapper, but I’m trying to use adapter for first time and I didn’t found the way how to do that.
Thanks
I use Spring Boot and leverage Spring Security’s support for OAuth 2.0 and Jason Web Tokens (JWTs). For example:
package org.serendipity.restapi.controller;
import org.serendipity.restapi.hateoas.IndividualRepresentationModelAssembler;
import org.serendipity.restapi.model.Individual;
import org.serendipity.restapi.service.IndividualService;
import org.springframework.data.rest.webmvc.BasePathAwareController;
import org.springframework.hateoas.CollectionModel;
import org.springframework.hateoas.EntityModel;
import org.springframework.http.HttpStatus;
import org.springframework.http.ResponseEntity;
import org.springframework.security.access.prepost.PreAuthorize;
import org.springframework.security.core.annotation.AuthenticationPrincipal;
import org.springframework.security.oauth2.jwt.Jwt;
import org.springframework.web.bind.annotation.GetMapping;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.server.ResponseStatusException;
@BasePathAwareController
public class IndividualController {
private final IndividualRepresentationModelAssembler assembler;
private final IndividualService entityService;
public IndividualController(IndividualService entityService,
IndividualRepresentationModelAssembler assembler) {
this.entityService = entityService;
this.assembler = assembler;
@GetMapping("/whoami")
public String whoami(@AuthenticationPrincipal Jwt jwt) {
return String.format("Hello, %s!", jwt.getSubject());
@GetMapping("/individuals")
@PreAuthorize("hasAuthority('SCOPE_individual:read')")
public ResponseEntity<CollectionModel<EntityModel<Individual>>> findAll() {
return ResponseEntity.ok(assembler.toCollectionModel(entityService.findAll()));
@GetMapping("/individuals/{id}")
public ResponseEntity<EntityModel<Individual>> findById(
@PathVariable("id") final Long id) throws ResponseStatusException {
Individual entity = entityService.findById(id).orElseThrow(() ->
new ResponseStatusException(HttpStatus.NOT_FOUND));
return ResponseEntity.ok(assembler.toModel(entity));
Ref: Flowable OAuth2 Resource Server
bilak
March 30, 2020, 6:39am
3
Well, you are not using keycloak adapter are you? That looks like spring customised configuration.
@bilak , did you find a solution?
