So I’ve installed the Keycloak 18.0.0 as docker and I get this error when I’m trying to login as admin: Unable to find factory for Required Action: CONFIGURE_RECOVERY_AUTHN_CODES
It’s very strange, because I have just this ENV KC_FEATURES=authorization,impersonation,client-policies,dynamic-scopes
as features. I must say that I’ve tried the recovery_code function with another pod, that used the same DB (so one solution will be to delete the db, but let’s say I don’t want to do that, is there another way?)
Any ideas?
And just as curiosity, is there a documentation on how actually to do the code recovery stuff? (Didn’t find anything to understand better the process).
Detailed error:
[org.keycloak.services] (executor-thread-0) KC-SERVICES0013: Failed authentication: java.lang.RuntimeException: Unable to find factory for Required Action: CONFIGURE_RECOVERY_AUTHN_CODES did you forget to declare it in a META-INF/services file?
at org.keycloak.services.managers.AuthenticationManager.toRequiredActionFactory(AuthenticationManager.java:1411)
at org.keycloak.services.managers.AuthenticationManager.lambda$evaluateRequiredActionTriggers$18(AuthenticationManager.java:1373)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.forEachOrdered(ReferencePipeline.java:502)
at org.keycloak.services.managers.AuthenticationManager.evaluateRequiredActionTriggers(AuthenticationManager.java:1374)
at org.keycloak.services.managers.AuthenticationManager.nextRequiredAction(AuthenticationManager.java:1079)
at org.keycloak.authentication.AuthenticationProcessor.nextRequiredAction(AuthenticationProcessor.java:1136)
at org.keycloak.authentication.AuthenticationProcessor.authenticationComplete(AuthenticationProcessor.java:1126)
at org.keycloak.authentication.AuthenticationProcessor.authenticationAction(AuthenticationProcessor.java:998)
at org.keycloak.services.resources.LoginActionsService.processFlow(LoginActionsService.java:321)
at org.keycloak.services.resources.LoginActionsService.processAuthentication(LoginActionsService.java:292)
at org.keycloak.services.resources.LoginActionsService.authenticate(LoginActionsService.java:276)
at org.keycloak.services.resources.LoginActionsService.authenticateForm(LoginActionsService.java:349)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:71)
