We have setup Keycloak for our product solution in order to use it as the identity provider. We are going to import users from LDAP into the Keycloak database (Keycloak MySql production database). We also need to sync all the users from the Keycloak database (both local and LDAP) into an external database (MySql again) that is the database our product uses. We have a table in there to reflect the product users (systemusers).
Could you please help us understand what is the best way for syncing those users from Keycloak to our product database. I have read that there exist SCIM plugins that can do this, but we wont rely on that, we will implement something on our own. Therefore should we:
- extend the User Storage SPI (for writing to our external product database whenever a Keycloak user -LDAP or local- is updated) or
- extend the UserProfileProvider (the only documentation I found for this solution is in the javadocs)
- extend a custom Event Listener SPI (for writing to our external product database whenever a Keycloak user -LDAP or local - is updated)
In the first case, we will implement the UserStorageProvider, UserLookupProvider
and override the GetUserByUsername
method so that if the current’s session user in keycloak does not exists in the external database, we create it.
In the last case, we will implement the EventListenerProvider
and override the OnEvent
method to trigger sync CRUD operations to our product database whenever events such as UPDATE_PROFILE
happen.
The question I have is whether events will be triggered when Keycloak imports a user from LDAP too, or only when the user is updated through the admin console? Could you please tell me if there is way to detect these LDAP updates? With local users updated through admin, events such as UPDATE_PROFILE
are triggered but with LDAP, I am not sure if events are created that will help us to trigger the CRUD operations in our product database.
Or if the EventListenerProvider extension is not the correct way forward, then is the User Storage SPI Provider the correct way to implement this synchronisation between the 3 data stores?
[Update]
We have chosen to go forward with the UserStorageProvider and and UserLookupProvider extensions and the UserStorageProviderFactory. This implementation looks up the user in keycloak and if the user is found calls our backend restful APIs to create the user in our external database. However the issue we currently phased is that the UserStorageProviderFactory create method is not being invoked and the custom provider is not triggered to do the CRUD operations. Any ideas why this is happening?
Or maybe if this is not the correct approach, could you please suggest any alternatives?
Any help will be greatly appreciated! Many thanks!
