I am trying to get our DTAP environments in sync without rebuilding it every time. We have a clustered setup with a dedicated PostgreSQL DB for all 4 environments. What I would like to achieve is that we can promote the development environment (settings) to higher levels without manual clicking in the interface. The only way I could find in doing this is with Rest API calls. Is this correct? I know that there are other options, to get settings in keycloak, but they are not meant for keeping things in sync if I understand it correct or work partially.
Creating a script to maintain all settings through API is a tedious task if new versions also come into play with (probably) slightly different urls/settings as well.
any thoughts on this?
@torsten: I saw your reply in an different topic for the same issue. You mentioned a script to get things in sync. Is this private or public available? (I could not find it)
