I’ve been working on creating a SSO strategy across a couple systems I work with, and I think I solved most of the issues I’ve faced in the past to some level of success (if you want to know more details, maybe look for my threads here).
However, there are a couple of issues I don’t understand where they are arising from, but which I think may be related:
- AccessTokens being generated fail to pass validation, with the error message:
401: Unauthorized. Token has invalid signature
- The very first token that is issued, does not comply with the expected format/fields. However, a page refresh will produce the accessToken in the expected format. Still, this token suffers from an invalid signature.
I have a GH Repo setup ready to replicate this issue, and I captured the logs/tokens being generated on the LOGS.md file, which I’m also copying here bellow the post.
Could you please help me understand what is going on? Is the user creation flow the responsible for what is happening? Am I invalidating users when I shouldn’t?
Best Regards
First login (no user exists before this)
Keycloak Logs
21:58:57,662 INFO [com.mydomain.auth.provider.user.CustomUserStorageProviderFactory] (default task-4) [I63] creating new CustomUserStorageProvider
21:58:57,688 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I48] getUserByEmail(some.user@thirdparty.com)
21:58:57,688 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
21:58:57,691 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users:
21:58:57,691 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I70] no user in loadedusers.. getting from localstorage...
21:58:57,697 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I71] no user in localstorage.. creating ReadOnlyAdapter
21:58:57,703 INFO [com.mydomain.auth.provider.user.ReadOnlyUserAdapter] (default task-4) [I41] create new ReadOnlyUserAdapter(some.user@thirdparty.com)
21:58:57,742 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I57] supportsCredentialType(password)
21:58:57,743 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I35] getUserById(f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com)
21:58:57,743 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I41] getUserByUsername(some.user@thirdparty.com)
21:58:57,744 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
21:58:57,745 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users: com.mydomain.auth.provider.user.ReadOnlyUserAdapter@f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com
21:58:57,745 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I57] isValid(realm=mydomain,user=some.user@thirdparty.com,credentialInput.type=password)
21:58:57,746 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I57] supportsCredentialType(password)
21:58:58,761 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I9] Checking if temporary user exists..
21:58:58,762 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
21:58:58,762 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users: com.mydomain.auth.provider.user.ReadOnlyUserAdapter@f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com
21:58:58,762 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I10] Removing id=f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com; username=some.user@thirdparty.com from adapter
21:58:58,762 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I11] Adapter type: class com.mydomain.auth.provider.user.ReadOnlyUserAdapter
21:58:58,763 INFO [com.mydomain.auth.provider.user.UserModelFactory] (default task-4) Creating user model for: some.user@thirdparty.com
21:58:58,805 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I57] supportsCredentialType(otp)
21:58:58,815 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I35] getUserById(f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com)
21:58:58,815 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I41] getUserByUsername(some.user@thirdparty.com)
21:58:58,815 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
21:58:58,815 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users: org.keycloak.models.jpa.UserAdapter@fd66ee0d
21:58:59,052 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I35] getUserById(f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com)
21:58:59,052 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I41] getUserByUsername(some.user@thirdparty.com)
21:58:59,053 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
21:58:59,053 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users: org.keycloak.models.jpa.UserAdapter@fd66ee0d
21:58:59,058 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I35] getUserById(f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com)
21:58:59,058 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I41] getUserByUsername(some.user@thirdparty.com)
21:58:59,058 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
21:58:59,058 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users: org.keycloak.models.jpa.UserAdapter@fd66ee0d
21:58:59,093 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I30] close()
Resulting Token
eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICJNNmhhNDdmdnlMZkRVbGtYMy1jWjZHQS1xZzZPSE5vX3JrVG1qOEJ2by1zIn0.eyJleHAiOjE2NDQ1MzEyMzksImlhdCI6MTY0NDUzMDMzOSwiYXV0aF90aW1lIjoxNjQ0NTMwMzM5LCJqdGkiOiIzMTg1OThmMy05ODNlLTQwN2QtYTc4OS1iNGJlNDY1MzMxMDkiLCJpc3MiOiJodHRwOi8va2V5Y2xvYWs6OTkwMC9hdXRoL3JlYWxtcy9teWRvbWFpbiIsImF1ZCI6WyJodHRwczovL2Rldi5teWRvbWFpbi5jb20iLCJodHRwOi8vZGV2LnRoaXJkLXBhcnR5LmNvbS9hcGkvdjIvIiwiYWNjb3VudCJdLCJzdWIiOiJmOjI1NGMyNmE2LWQ5NzYtNGE1ZC05YmE3LWZjYThkMWRhMzhkMjpzb21lLnVzZXJAdGhpcmRwYXJ0eS5jb20iLCJ0eXAiOiJCZWFyZXIiLCJhenAiOiJpYW0iLCJub25jZSI6ImQ0ZmQzMmZkLTQ1NGEtNDFlYi04NTNiLTVmM2Q4ODU2NzBkNCIsInNlc3Npb25fc3RhdGUiOiI0ZmJhMGEwYi01YjU0LTRhN2MtODMzNy00NjEzZWYwMTg1NDIiLCJhY3IiOiIxIiwicmVhbG1fYWNjZXNzIjp7InJvbGVzIjpbIm9mZmxpbmVfYWNjZXNzIiwiZGVmYXVsdC1yb2xlcy1teWRvbWFpbiIsInVtYV9hdXRob3JpemF0aW9uIiwiYWMtY29uc3VtZXIiXX0sInJlc291cmNlX2FjY2VzcyI6eyJhY2NvdW50Ijp7InJvbGVzIjpbIm1hbmFnZS1hY2NvdW50IiwibWFuYWdlLWFjY291bnQtbGlua3MiLCJ2aWV3LXByb2ZpbGUiXX19LCJzY29wZSI6Im9wZW5pZCBlbWFpbCBtb250YmxhbmMgcHJvZmlsZSIsInNpZCI6IjRmYmEwYTBiLTViNTQtNGE3Yy04MzM3LTQ2MTNlZjAxODU0MiIsImVtYWlsX3ZlcmlmaWVkIjpmYWxzZSwiaHR0cDovL215ZG9tYWluLmNvbS91c2VyX3JvbGVzIjpbIm9mZmxpbmVfYWNjZXNzIiwiZGVmYXVsdC1yb2xlcy1teWRvbWFpbiIsInVtYV9hdXRob3JpemF0aW9uIiwiYWMtY29uc3VtZXIiXSwicHJlZmVycmVkX3VzZXJuYW1lIjoic29tZS51c2VyQHRoaXJkcGFydHkuY29tIn0.buH8B90Opvm-3Ql_d-dtrPse9ZL-cVsptCLPjp8gB9VMeVijHXiRZTD9YbdqxuGD24VHi1wD3uhCAypSNUtHvD4TOGBTYkXZedoVvc1uT4PO8eAxLVTZGcnY0oRtj5WK06hYAhf5F_8Cbp0Ed10ZXtCNR8AfJcmjya78gG7o3TmZeWP6Hui0G8A1ehfdE2fTypPEcxIUNfLs0mcNXba6BVcLS1Wge4Cr0gKBB4CoNEiWDOLypa0fd5KSFfnkr5bt7NCh-VIwAP9Br3nKAZa-belKXze95RW66SAu31Hxzf2mEGaTelK2zXlcKyCVaj7fLNR-nsnBZ7eI2ji3-N1RMw
Refresh page
Keycloak Logs
22:02:21,983 INFO [com.mydomain.auth.provider.user.CustomUserStorageProviderFactory] (default task-4) [I63] creating new CustomUserStorageProvider
22:02:21,984 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I35] getUserById(f:254c26a6-d976-4a5d-9ba7-fca8d1da38d2:some.user@thirdparty.com)
22:02:21,984 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I41] getUserByUsername(some.user@thirdparty.com)
22:02:21,984 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I69] findUser(identifier=some.user@thirdparty.com)
22:02:21,984 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) Loaded Users:
22:02:21,984 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I70] no user in loadedusers.. getting from localstorage...
22:02:22,122 INFO [com.mydomain.auth.provider.user.CustomUserStorageProvider] (default task-4) [I30] close()
Resulting Token
eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICJNNmhhNDdmdnlMZkRVbGtYMy1jWjZHQS1xZzZPSE5vX3JrVG1qOEJ2by1zIn0.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.i7fJ43Aa3Wv_06OUw1xXmJVPNCIHnYZt7zul4_WBxzuKdjsbsPzZhiPIIP0qUBIFj3eelkRxsey_5AruAOqjCnSlLRHvKRhonzye8tLJY0iTfQ-t_JXQ0uInXRLQMJBa7o80QLTvr3Jxxn97Y5nK195l4th_nJvZmZU5oCBbQTDBpBUOXzTWuW0odm-UsQxa_9q4ClMxAXU4Cm1y3JYXRe8UQbVjdGvsq8FL16fJRLbQ6cMbqjvyvxWjispCIvvsWOL7ekLDRJ4HMTFHtBXC-0W78-iHlL6fGqZuJnsdfffqXXYdxFRlNbovAqvpbBW7MNjt8bqRnT3ny47BbFQQqg
