I’m having trouble to find the option for configuring a truststore. In the Advanced Settings of LDAP there is a tooltip that points to a file named standalone.xml/domain.xml, but this only seems to exist in the WildFly-distribution and not in the Quarkus one we use.
The goal is to import the certificate of the LDAP server to use LDAPS/TLS. If somebody could shed some light on this issue I really would appreciate.
Thank you,
Stefan
You have to create the truststore file externally, copy it into the Keycloak image and configure it with these properties: Keycloak - Server - All configuration
breed
March 20, 2022, 7:15pm
#4
Hi @stefan1 @dasniko
I have a same problem but not works for me.
I define trust store and import cert in dockerfile.
Don’t know where the mistake is?
ENV KC_HTTPS_TRUST_STORE_FILE=conf/ldap-test.jks
ENV KC_HTTPS_TRUST_STORE_PASSWORD=PW1
RUN keytool -import -noprompt -trustcacerts -storepass PW1 -alias ldap-test -file ldap-test.cer -keystore conf/ldap-test.jks
Thank you
Breed
Sorry, I directly modified the conf/keycloak.conf, don’t know how it works with docker.
EDIT: doesn’t work for me either, I thought it worked at first glance, but it was only the LDAP-Connection-Test that worked. But when I try to authenticate I get this error - same as if i didn’t configure a truststore:
javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I added the following options to the conf/keycloak.conf:
https-trust-store-file=/opt/keycloak/truststore.jks
https-trust-store-password=********************
and added the CA-Certificate of the LDAP-Server with this command:
keytool -importcert -v -trustcacerts -alias ucs-ca -file ucsCAcert.pem -keystore truststore.jks
I also tried to add the certificate of the LDAP-Server:
rm truststore.jks
keytool -import -alias dc.ourdomain.de -keystore truststore.jks -file dc.ourdomain.de.cer
– same error
Ok it works with the default java keystore - for me on Ubuntu it was:
keytool -importcert -alias ucs-CA -keystore /usr/lib/jvm/default-java/lib/security/cacerts -file ucsCAcert.pem
https://plone.lucidsolutions.co.nz/linux/java/how-to-add-a-certificate-authority-ca-certificate-to-the-openjdk-cacerts
Still wondering why it doesn’t work with a custom added truststore.
@breed @dasniko
Found the right parameter:
--spi-truststore-file-file
and --spi-truststore-file-password
were the parameters i was looking for
And here is described how to add host certificates to the truststore (dunno if it also works with CA-Certificates, but I think so):
https://www.keycloak.org/docs/latest/server_installation/index.html#_truststore
breed
March 22, 2022, 1:41pm
#8
@stefan1 thank you for your reply.
But not works for me still.
ENV KC_SPI_TRUSTSTORE_FILE_FILE=conf/ldap-test.jks
ENV KC_SPI_TRUSTSTORE_FILE_PASSWORD=PW
RUN keytool -importcert -alias ldaptest-CA -storepass PW -noprompt -file /opt/keycloak/ldap-test.cer -keystore conf/ldap-test.jks
breed
March 22, 2022, 8:26pm
#9
Similar problem with using
ENV KC_SPI_TRUSTSTORE_FILE_....
opened 05:01PM - 22 Mar 22 UTC
kind/bug
status/triage
### Describe the bug
After switching from KC16 to KC17, verification of the d… atabase certs are not working anymore. In KC16, we set the trust store and parameters for verification via ENVs:
JAVA_OPTS='-Djavax.net.ssl.trustStore=/certs/truststore.jks -Djavax.net.ssl.trustStorePassword=[PASSWORD]'
JDBC_PARAMS: "verifyServerCertificate=true&useSSL=true&requireSSL=true&enabledTLSProtocols=TLSv1,TLSv1.1,TLSv1.2,TLSv1.3"
In KC17, we set:
KC_DB_URL= "jdbc:mysql://[AURORA_MYSQL_URL]:3306/keycloak_17_0_0?user=[USERNAME]&password=[PASSWORD]&verifyServerCertificate=true&useSSL=true&requireSSL=true&enabledTLSProtocols=TLSv1,TLSv1.1,TLSv1.2,TLSv1.3&characterEncoding=UTF-8"
KC_SPI_TRUSTSTORE_FILE_FILE= "/certs/truststore.jks"
KC_SPI_TRUSTSTORE_FILE_PASSWORD="[PASSWORD]"
Changing the trust store path or password results in an error, hence, the trust store seems to be loaded correctly.
### Version
17.0.0
### Expected behavior
Since the trust store has not changed at all, we expect that the certificate verification works in KC17, too. If we change the parameter `verifyServerCertificate` to `False` the error disappears.
### Actual behavior
The following exception is thrown:
2022-03-22 11:52:26,680 WARN [io.agroal.pool] (agroal-11) Datasource '<default>': Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
2022-03-22 11:52:26,682 WARN [org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator] (JPA Startup Thread: keycloak-default) HHH000342: Could not obtain connection to query metadata: com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
at com.mysql.cj.jdbc.exceptions.SQLError.createCommunicationsException(SQLError.java:174)
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:64)
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:829)
at com.mysql.cj.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:449)
at com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:242)
at com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:198)
at com.mysql.cj.jdbc.MysqlDataSource.getConnection(MysqlDataSource.java:416)
at com.mysql.cj.jdbc.MysqlDataSource.getConnection(MysqlDataSource.java:128)
at com.mysql.cj.jdbc.MysqlDataSource.getConnection(MysqlDataSource.java:113)
at com.mysql.cj.jdbc.MysqlXADataSource.getXAConnection(MysqlXADataSource.java:52)
at io.agroal.pool.ConnectionFactory.createConnection(ConnectionFactory.java:216)
at io.agroal.pool.ConnectionPool$CreateConnectionTask.call(ConnectionPool.java:513)
at io.agroal.pool.ConnectionPool$CreateConnectionTask.call(ConnectionPool.java:494)
at io.agroal.pool.util.PriorityScheduledExecutor.beforeExecute(PriorityScheduledExecutor.java:75)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1126)
Caused by: com.mysql.cj.exceptions.CJCommunicationsException: Communications link failure
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:61)
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:105)
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:151)
at com.mysql.cj.exceptions.ExceptionFactory.createCommunicationsException(ExceptionFactory.java:167)
at com.mysql.cj.protocol.a.NativeProtocol.negotiateSSLConnection(NativeProtocol.java:317)
at com.mysql.cj.protocol.a.NativeAuthenticationProvider.connect(NativeAuthenticationProvider.java:204)
at com.mysql.cj.protocol.a.NativeProtocol.connect(NativeProtocol.java:1369)
at com.mysql.cj.NativeSession.connect(NativeSession.java:133)
at com.mysql.cj.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:949)
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:819)
... 15 more
Caused by: javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors
at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:131)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:352)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:295)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:290)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:654)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(CertificateMessage.java:473)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(CertificateMessage.java:369)
at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392)
at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:443)
at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:421)
at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:182)
at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:172)
at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1501)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1411)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:451)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:422)
at com.mysql.cj.protocol.ExportControlled.performTlsHandshake(ExportControlled.java:347)
at com.mysql.cj.protocol.StandardSocketFactory.performTlsHandshake(StandardSocketFactory.java:194)
at com.mysql.cj.protocol.a.NativeSocketConnection.performTlsHandshake(NativeSocketConnection.java:101)
at com.mysql.cj.protocol.a.NativeProtocol.negotiateSSLConnection(NativeProtocol.java:308)
... 20 more
Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors
at com.mysql.cj.protocol.ExportControlled$X509TrustManagerWrapper.checkServerTrusted(ExportControlled.java:408)
at java.base/sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(SSLContextImpl.java:1549)
at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:638)
... 35 more
Caused by: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors
at java.base/sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:157)
at java.base/sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:83)
at java.base/java.security.cert.CertPathValidator.validate(CertPathValidator.java:309)
at com.mysql.cj.protocol.ExportControlled$X509TrustManagerWrapper.checkServerTrusted(ExportControlled.java:402)
... 37 more
2022-03-22 11:52:26,895 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000128: Infinispan version: Infinispan 'Triskaidekaphobia' 13.0.5.Final
2022-03-22 11:52:27,062 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000078: Starting JGroups channel `ISPN`
2022-03-22 11:52:27,069 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000088: Unable to use any JGroups configuration mechanisms provided in properties {}. Using default JGroups configuration!
2022-03-22 11:52:27,183 WARN [org.jgroups.protocols.UDP] (keycloak-cache-init) JGRP000015: the send buffer of socket MulticastSocket was set to 1.00MB, but the OS only allocated 212.99KB
2022-03-22 11:52:27,184 WARN [org.jgroups.protocols.UDP] (keycloak-cache-init) JGRP000015: the receive buffer of socket MulticastSocket was set to 20.00MB, but the OS only allocated 212.99KB
2022-03-22 11:52:27,184 WARN [org.jgroups.protocols.UDP] (keycloak-cache-init) JGRP000015: the send buffer of socket MulticastSocket was set to 1.00MB, but the OS only allocated 212.99KB
2022-03-22 11:52:27,185 WARN [org.jgroups.protocols.UDP] (keycloak-cache-init) JGRP000015: the receive buffer of socket MulticastSocket was set to 25.00MB, but the OS only allocated 212.99KB
2022-03-22 11:52:29,199 INFO [org.jgroups.protocols.pbcast.GMS] (keycloak-cache-init) keycloak-17-698bdc8c8b-sn5s2-48664: no members discovered after 2003 ms: creating cluster as coordinator
2022-03-22 11:52:29,209 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000094: Received new cluster view for channel ISPN: [keycloak-17-698bdc8c8b-sn5s2-48664|0] (1) [keycloak-17-698bdc8c8b-sn5s2-48664]
2022-03-22 11:52:29,213 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000079: Channel `ISPN` local address is `keycloak-17-698bdc8c8b-sn5s2-48664`, physical addresses are `[192.168.150.92:44031]`
2022-03-22 11:52:29,825 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: keycloak-17-698bdc8c8b-sn5s2-48664, Site name: null
2022-03-22 11:52:29,910 WARN [io.agroal.pool] (agroal-11) Datasource '<default>': Communications link failure
2022-03-22 11:52:29,929 INFO [org.infinispan.CLUSTER] (main) ISPN000080: Disconnecting JGroups channel `ISPN`
2022-03-22 11:52:29,973 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (production) mode
2022-03-22 11:52:29,973 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to obtain JDBC connection
2022-03-22 11:52:29,973 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Communications link failure
2022-03-22 11:52:29,974 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Communications link failure
2022-03-22 11:52:29,974 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors
2022-03-22 11:52:29,975 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Path does not chain with any of the trust anchors
2022-03-22 11:52:29,975 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) For more details run the same command passing the '--verbose' option. Also you can use '--help' to see the details about the usage of the particular command.
### How to Reproduce?
_No response_
### Anything else?
The keystore contains the [aws rds root certificate](https://s3.amazonaws.com/rds-downloads/rds-ca-2019-root.pem) and the [Starfield Services Root Certificate Authority](https://www.amazontrust.com/repository/), both added (in that order) via:
keytool -import -alias mysqlServerCACert -file rds-ca-2019-root.pem -keystore truststore.jks
keytool -import -alias aws_root_starfield -file aws_root_starfield.pem -keystore truststore.jks
