I am trying to test a scenario of 2 keycloaks where one is identity provider for the other, but I keep getting a 502 error with both them on localhost… is it possible?
Here is my simple testcase:
docker-compose.yml
services:
keycloak1:
image: "quay.io/keycloak/keycloak:latest"
ports:
- "1234:8080"
environment:
KEYCLOAK_USER: admin1
KEYCLOAK_PASSWORD: admin
keycloak2:
ports:
- "4321:8080"
environment:
KEYCLOAK_USER: admin2
Since I am a new user, I cant post pictures, I will describe the steps textually, for a more visual bug report see here Keycloak Discourse Bug Report · Issue #9 · stenagam/demo-federated-module-login · GitHub
Keycloak 1 (http://localhost:1234
- new realm named
realm_a
- user registration enabled, SSL disabled
- new client named
keycloak2
- access type:
confidential
- wildcards on Valid Redirect URIs and Web Origins:
- Valid Redirect URIs:
http://localhost:4321/*
- Web Origins:
- client secret copied from “Credentials” tab
- access type:
finishing with admin1 Sign Out
Keycloak 2 (http://localhost:4321
- new realm named
realm_b
- user registration On, SSL Off
- new identity provider Keycloak OpenID Connect
- auth endpoint:
http://localhost:1234/auth/realms/realm_a/protocol/openid-connect/auth
- token endpoint:
http://localhost:1234/auth/realms/realm_a/protocol/openid-connect/token
- Client Authentication:
Client secret sent as post
- Client ID:
keycloak2
- Client Secret:
<paste>
- auth endpoint:
Save and SignOut admin2
Keycloak 1 from user perspective
Open http://localhost:1234/auth/realms/realm_a/account
and SignIn to register a new user.
After success login, signout
Keycloak 2 from user perspective
Open http://localhost:4321/auth/realms/realm_b/account
and attempt to Sign In using the Identity Provider.
After click on “keycloak1” button, sign in. The session is open on keycloak 1 but the redirect is to an error page.
We are sorry...
Unexpected error when authenticating with identity provider
Logs
keycloak2_1 | 12:31:38,803 WARN [org.keycloak.connections.httpclient.DefaultHttpClientFactory] (default task-13) TruststoreProvider is disabled
keycloak2_1 | 12:31:38,889 ERROR [org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider] (default task-13) Failed to make identity provider oauth callback: org.apache.http.conn.HttpHostConnectException: Connect to localhost:1234 [localhost/127.0.0.1] failed: Connection refused (Connection refused)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:156)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:376)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
keycloak2_1 | at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.broker.provider.util.SimpleHttp.makeRequest(SimpleHttp.java:277)
keycloak2_1 | at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.broker.provider.util.SimpleHttp.asResponse(SimpleHttp.java:216)
keycloak2_1 | at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.broker.provider.util.SimpleHttp.asString(SimpleHttp.java:208)
keycloak2_1 | at org.keycloak.keycloak-services@15.0.2//org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider$Endpoint.authResponse(AbstractOAuth2IdentityProvider.java:500)
keycloak2_1 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
keycloak2_1 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
keycloak2_1 | at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
keycloak2_1 | at java.base/java.lang.reflect.Method.invoke(Method.java:566)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:546)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:435)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:396)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:358)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:398)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:365)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:110)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:141)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:245)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:61)
keycloak2_1 | at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
keycloak2_1 | at javax.servlet.api@2.0.0.Final//javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
keycloak2_1 | at org.keycloak.keycloak-wildfly-extensions@15.0.2//org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
keycloak2_1 | at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
keycloak2_1 | at org.keycloak.keycloak-wildfly-extensions@15.0.2//org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
keycloak2_1 | at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:117)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
keycloak2_1 | at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
keycloak2_1 | at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
keycloak2_1 | at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
keycloak2_1 | at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
keycloak2_1 | at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:387)
keycloak2_1 | at io.undertow.core@2.2.5.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:841)
keycloak2_1 | at org.jboss.threads@2.4.0.Final//org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
keycloak2_1 | at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1990)
keycloak2_1 | at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
keycloak2_1 | at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
keycloak2_1 | at org.jboss.xnio@3.8.4.Final//org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1280)
keycloak2_1 | at java.base/java.lang.Thread.run(Thread.java:829)
keycloak2_1 | Caused by: java.net.ConnectException: Connection refused (Connection refused)
keycloak2_1 | at java.base/java.net.PlainSocketImpl.socketConnect(Native Method)
keycloak2_1 | at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
keycloak2_1 | at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
keycloak2_1 | at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
keycloak2_1 | at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
keycloak2_1 | at java.base/java.net.Socket.connect(Socket.java:609)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75)
keycloak2_1 | at org.apache.httpcomponents.core//org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
keycloak2_1 | ... 90 more
keycloak2_1 |
keycloak2_1 | 12:31:38,924 WARN [org.keycloak.events] (default task-13) type=IDENTITY_PROVIDER_LOGIN_ERROR, realmId=realm_b, clientId=account-console, userId=null, ipAddress=172.24.0.1, error=identity_provider_login_failure, code_id=ff4c5f88-7047-4462-ac77-4f7912655874, authSessionParentId=ff4c5f88-7047-4462-ac77-4f7912655874, authSessionTabId=QYSgucrsGvc
Browser Network Tab
(have a 502 request in it)
What am I missing? Is it possible to have the identity provider and the broker on the same machine?
Thanks!
