Good afternoon,
I tried to customize the login theme by adding german translations.
However, I’m facing issues with umlauts not being displayed properly.
When I directly put ä,ö,ü into the properties file only weird signs will be rendered.
When using the html representation ä in the properties file it works sometimes (umlauts are correctly displayed), but not every time (the html representation is displayed).
It seems to be related to a call to kcSanitize around the message. When it is called umlauts are displayed properly.
Do I have to edit all themes to include calls to kcSanitize for all affected messages or is there a simpler way for direct utf-8 support?
Thanks in advance.
