Hello All,
I am using keycloak operator to install keycloak and i have configured keycloak to use external database (RDS instance). ==> (externalDatabase: true)
The keycloak instances are up and running without any issues.
When i tried to login to the keycloak UI with master realm credentials it is telling that the credentials are invalid, though the credentials are correct.
I am getting the credentials using the following command.
kubectl get secret credential-test -o go-template='{{range $k,$v := .data}}{{printf "%s: " $k}}{{if not $v}}{{$v}}{{else}}{{$v | base64decode}}{{end}}{{"\n"}}{{end}}'
The following is the log from the instance.
07:40:48,172 WARN [org.keycloak.events] (default task-1) type=LOGIN_ERROR, realmId=master, clientId=security-admin-console, userId=566f4e3e-c0f1-4304-bca2-686321d88b87, ipAddress=10.242.3.61, error=invalid_user_credentials, auth_method=openid-connect, auth_type=code, redirect_uri=https://test123.net/auth/admin/master/console/, code_id=5561bc9e-e2b9-41e3-836d-37add6e74c1c, username=admin, authSessionParentId=5561bc9e-e2b9-41e3-836d-37add6e74c1c, authSessionTabId=Oq-orhggRE4
Any advice or suggestion is highly appreciated.
