Hi All,
Need help on the below;
getting page not found error
F:>softwares\keycloak-20.0.3\bin\kc.bat start-dev
2023-03-07 10:16:52,600 INFO
[org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider] (main) Hostname settings: Base URL: , Hostname: , Strict HTTPS: false, Path: , Strict BackChannel: false, Admin URL: , Admin: , Port: -1, Proxied: false
2023-03-07 10:16:53,851 WARN [io.quarkus.agroal.runtime.DataSources] (main) Datasource enables XA but transaction recovery is not enabled. Please enable transaction recovery by setting quarkus.transaction-manager.enable-recovery=true, otherwise data may be lost if the application is terminated abruptly
2023-03-07 10:16:55,054 WARN [org.infinispan.PERSISTENCE] (keycloak-cache-init) ISPN000554: jboss-marshalling is deprecated and planned for removal
2023-03-07 10:16:55,086 WARN [org.infinispan.CONFIG] (keycloak-cache-init) ISPN000569: Unable to persist Infinispan internal caches as no global state enabled
2023-03-07 10:16:55,102 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000556: Starting user marshaller âorg.infinispan.jboss.marshalling.core.JBossUserMarshallerâ
2023-03-07 10:16:55,439 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000128: Infinispan version: Infinispan âTriskaidekaphobiaâ 13.0.10.Final
2023-03-07 10:16:58,881 INFO [org.keycloak.broker.provider.AbstractIdentityProviderMapper] (main) Registering class org.keycloak.broker.provider.mappersync.ConfigSyncEventListener
2023-03-07 10:16:59,071 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: node_330926, Site name: null
2023-03-07 10:16:59,810 INFO [io.quarkus] (main) Keycloak 20.0.3 on JVM (powered by Quarkus 2.13.6.Final) started in 8.910s. Listening on: http://0.0.0.0:8080
2023-03-07 10:16:59,810 INFO [io.quarkus] (main) Profile dev activated.
2023-03-07 10:16:59,810 INFO [io.quarkus] (main) Installed features: [agroal, cdi, hibernate-orm, jdbc-h2, jdbc-mariadb, jdbc-mssql, jdbc-mysql, jdbc-oracle, jdbc-postgresql, keycloak, logging-gelf, narayana-jta, reactive-routes, resteasy, resteasy-jackson, smallrye-context-propagation, smallrye-health, smallrye-metrics, vault, vertx]
2023-03-07 10:16:59,810 WARN [org.keycloak.quarkus.runtime.KeycloakMain] (main) Running the server in development mode. DO NOT use this configuration in production.
