Hi all,
Need help in below faced issue in the implementation of Keycloak redirection in flutter web application.
Flutter Package Used : keycloak_flutter | Flutter Package
Above package has used Keycloak JS adapter implementation. to achieve keycloak redirection in flutter web application using below reference.
Reference : Securing Applications and Services Guide
Describe the bug :
Using the package i am trying to refresh the access token by calling updateToken method which makes the refreshtoken api request from keyclaok.js. but the request returns Status 400 Bad Request ,then i checked the request in browser tool(network tab),the refresh_token is passed as undefined. I also tried to passed -1 as parameter to the updateToken() which forcefully refresh the token.
access_token expires in : 1 min
Expected behavior :
The updatetoken method should refreshtoken if access token is expiry.
Also Observed
- Immediately after successfully login OnAuthLogout event is fired
- the token expired event is not fired even after the token is expired
Thanks in Advance.
