Hi
We are trying to upgrade Keycloak from 14.0 to 15.1 but after all steps are complete, the database upgrade is failing with: META-INF/jpa-changelog-master.xml : Index Exists Precondition: IDX_CLIENT_ATT_BY_NAME_VALUE on CLIENT_ATTRIBUTES : Unknown constraint type: 3
We are running MSSQL: SQL Server 15.0.4138.2
I have tried the following JDBC connectors:
- mssql-jdbc-9.4.0.jre8.jar
- mssql-jdbc-6.4.0.jre8.jar
- mssql-jdbc-6.2.2.jre8.jar
- mssql-jdbc-7.0.0.jre8.jar
Edit: Is it related to this liquidbase bug?
Setting migrationStrategy to manual does not help, and it generates an almost empty .sql file before crashing with the following:
2021-08-12 10:58:58,769 ERROR [org.keycloak.connections.jpa.updater.liquibase.conn.DefaultLiquibaseConnectionProvider] (ServerService Thread Pool -- 62) Change Set META-INF/jpa-changelog-14.0.0.xml::14.0.0-KEYCLOAK-18286-revert::keycloak failed. Error: Migration failed for change set META-INF/jpa-changelog-14.0.0.xml::14.0.0-KEYCLOAK-18286-revert::keycloak:
Reason:
2021-08-12 10:58:58,769 ERROR [org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider] (ServerService Thread Pool -- 62) Error has occurred while updating the database: liquibase.exception.MigrationFailedException: Migration failed for change set META-INF/jpa-changelog-14.0.0.xml::14.0.0-KEYCLOAK-18286-revert::keycloak:
Reason:
at org.liquibase//liquibase.changelog.ChangeSet.execute(ChangeSet.java:541)
at org.liquibase//liquibase.changelog.visitor.UpdateVisitor.visit(UpdateVisitor.java:51)
at org.liquibase//liquibase.changelog.ChangeLogIterator.run(ChangeLogIterator.java:79)
at org.liquibase//liquibase.Liquibase.update(Liquibase.java:214)
at org.liquibase//liquibase.Liquibase.update(Liquibase.java:277)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.updateChangeSet(LiquibaseJpaUpdaterProvider.java:182)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:103)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.export(LiquibaseJpaUpdaterProvider.java:87)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory$3.run(DefaultJpaConnectionProviderFactory.java:371)
at org.keycloak.keycloak-server-spi-private@15.0.1//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:250)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.export(DefaultJpaConnectionProviderFactory.java:364)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.migration(DefaultJpaConnectionProviderFactory.java:339)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lambda$lazyInit$0(DefaultJpaConnectionProviderFactory.java:184)
at org.keycloak.keycloak-server-spi-private@15.0.1//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:758)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lazyInit(DefaultJpaConnectionProviderFactory.java:135)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:83)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:61)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.DefaultKeycloakSession.getProvider(DefaultKeycloakSession.java:316)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:63)
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:39)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.DefaultKeycloakSession.realmLocalStorage(DefaultKeycloakSession.java:228)
at org.keycloak.keycloak-model-infinispan@15.0.1//org.keycloak.models.cache.infinispan.RealmCacheSession.getRealmDelegate(RealmCacheSession.java:149)
at org.keycloak.keycloak-model-infinispan@15.0.1//org.keycloak.models.cache.infinispan.RealmCacheSession.getRealm(RealmCacheSession.java:411)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.managers.ApplianceBootstrap.isNewInstall(ApplianceBootstrap.java:46)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.resources.KeycloakApplication$3.run(KeycloakApplication.java:195)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.resources.KeycloakApplication.bootstrap(KeycloakApplication.java:172)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:136)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:128)
at org.keycloak.keycloak-wildfly-extensions@15.0.1//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:36)
at org.keycloak.keycloak-services@15.0.1//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:114)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:481)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2835)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:376)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:288)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:98)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:140)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:588)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:559)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:601)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at java.base/java.lang.Thread.run(Thread.java:832)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
Caused by: liquibase.exception.PreconditionErrorException: Precondition Error
at org.liquibase//liquibase.precondition.core.IndexExistsPrecondition.check(IndexExistsPrecondition.java:121)
at org.liquibase//liquibase.precondition.core.AndPrecondition.check(AndPrecondition.java:43)
at org.liquibase//liquibase.precondition.core.PreconditionContainer.check(PreconditionContainer.java:202)
at org.liquibase//liquibase.changelog.ChangeSet.execute(ChangeSet.java:498)
... 69 more
Caused by: liquibase.exception.DatabaseException: liquibase.exception.DatabaseException: Unknown constraint type: 3
at org.liquibase//liquibase.snapshot.jvm.ForeignKeySnapshotGenerator.snapshotObject(ForeignKeySnapshotGenerator.java:178)
at org.liquibase//liquibase.snapshot.jvm.JdbcSnapshotGenerator.snapshot(JdbcSnapshotGenerator.java:60)
at org.liquibase//liquibase.snapshot.SnapshotGeneratorChain.snapshot(SnapshotGeneratorChain.java:50)
at org.liquibase//liquibase.snapshot.jvm.JdbcSnapshotGenerator.snapshot(JdbcSnapshotGenerator.java:63)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.include(DatabaseSnapshot.java:246)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.replaceObject(DatabaseSnapshot.java:363)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.includeNestedObjects(DatabaseSnapshot.java:293)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.include(DatabaseSnapshot.java:267)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.replaceObject(DatabaseSnapshot.java:343)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.init(DatabaseSnapshot.java:80)
at org.liquibase//liquibase.snapshot.DatabaseSnapshot.<init>(DatabaseSnapshot.java:53)
at org.liquibase//liquibase.snapshot.JdbcDatabaseSnapshot.<init>(JdbcDatabaseSnapshot.java:28)
at org.liquibase//liquibase.snapshot.SnapshotGeneratorFactory.createSnapshot(SnapshotGeneratorFactory.java:150)
at org.liquibase//liquibase.snapshot.SnapshotGeneratorFactory.createSnapshot(SnapshotGeneratorFactory.java:158)
at org.liquibase//liquibase.snapshot.SnapshotGeneratorFactory.has(SnapshotGeneratorFactory.java:108)
at org.liquibase//liquibase.precondition.core.IndexExistsPrecondition.check(IndexExistsPrecondition.java:101)
... 72 more
Caused by: liquibase.exception.DatabaseException: Unknown constraint type: 3
at org.liquibase//liquibase.snapshot.jvm.ForeignKeySnapshotGenerator.convertToForeignKeyConstraintType(ForeignKeySnapshotGenerator.java:200)
at org.liquibase//liquibase.snapshot.jvm.ForeignKeySnapshotGenerator.snapshotObject(ForeignKeySnapshotGenerator.java:150)
... 90 more
2021-08-12 10:58:58,980 FATAL [org.keycloak.services] (ServerService Thread Pool -- 62) Error during startup: java.lang.RuntimeException: Failed to update database
at org.keycloak.keycloak-model-jpa@15.0.1//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:118)
Caused by: liquibase.exception.MigrationFailedException: Migration failed for change set META-INF/jpa-changelog-14.0.0.xml::14.0.0-KEYCLOAK-18286-revert::keycloak:
Reason:
... 63 more
... 69 more
... 72 more
... 90 more
