When I try to upgrade keycloak from 18.0.1 to 19.0.0, the application starts from in-memory database.
The db configuration was working fine with 18.0.1, but not in 19.0.0.
My docker file looks like below.
FROM Quay as builder
ENV KC_HEALTH_ENABLED=true
ENV KC_METRICS_ENABLED=true
ENV KC_FEATURES=token-exchange,docker
ENV KC_DB=postgres
ENV KC_CACHE_STACK=kubernetes
ENV KC_TRANSACTION_XA_ENABLED=false
WORKDIR /opt/keycloak
RUN curl -O -k https:///themes/mytheme.jar
RUN cp *.jar /opt/keycloak/providers/
FROM Quay
COPY --from=builder /opt/keycloak/lib/quarkus/ /opt/keycloak/lib/quarkus/
COPY --from=builder /opt/keycloak/providers/ /opt/keycloak/providers/
ENV KC_SPI_EVENTS_LISTENER_JBOSS_LOGGING_SUCCESS_LEVEL=INFO
ENV KC_SPI_EVENTS_LISTENER_JBOSS_LOGGING_ERROR_LEVEL=ERROR
ENTRYPOINT [“/opt/keycloak/bin/kc.sh”, “start”]
The database configuration in the helm chart is given below:
- name: KC_DB_URL_HOST
value: DB-URL
- name: KC_DB_URL_DATABASE
value: DB-NAME
- name: KC_DB_URL_PROPERTIES
value: "?sendStringParametersAsUnicode=false"
- name: KC_DB_USERNAME
value: "<username>"
- name: KC_DB_PASSWORD
value: "<password>"
- name: KC_DB_POOL_MIN_SIZE
value: "1"
- name: KC_DB_POOL_MAX_SIZE
value: "50"
Anybody faced this issue, or is there any change in configuration while upgrading to version 19.0.0?
Please help.
