We have a single page app (SPA) that runs on <DOMAIN>. Calls to <DOMAIN>/graphql are rerouted to the backend. Both the frontend and backend are secured via a Keycloak Gatekeeper instance.
The idea was that the frontend and backend share the kc-access token.
Now, the access token expires in the backend Gatekeeper. If we refresh the spa in the browser the frontend is rerouted to Keycloak and a fresh access token is required. But if we do not refresh all POST requests to <DOMAIN>/graphql fail with a 307 status code when the token has expired. The browser does not know how to handle this. We see an “{“error”:“RESTEASY003065: Cannot consume content type”}”. If the content-type header of the POST is removed the error is “no client_id provided”, while the client_id is included in the query string.
Redirecting a POST request to Keycloak would probably not be the best solution. Cleaner would be if the backend refreshes it’s access token itself.
This is what we tried by adding a session state store to the backend’s Gatekeeper. We are using the following configuration:
- --discovery-url=DISCOVERY_URL
- --client-id=CLIENT_ID
- --client-secret=****
- --enable-refresh-tokens=true
- --encryption-key=0123456789012345
- --store-url=boltdb:///boltdb
- --listen=0.0.0.0:3001
- --verbose=true
- --redirection-url=REDIRECTION_URL
- --upstream-url=http://127.0.0.1:3000
This does create a /boltdb file in the Gatekeeper, but it does not seem to be used since the file does not change.
The backend’s Gatekeeper gives the following logging:
1.5716729131430433e+09 | debug | keycloak-gatekeeper/session.go:51 | found the user identity | {“id”: “b5b659cd-148e-4f23-bf2f-28e6f207f6c7”, “name”: “piet”, “email”: “”, “roles”: “offline_access,dashboard_viewer,uma_authorization,account:manage-account,account:manage-account-links,account:view-profile”, “groups”: “”} |
1.5716729131462774e+09 | info | keycloak-gatekeeper/middleware.go:154 | accces token for user has expired, attemping to refresh the token | {“client_ip”: “****”, “email”: “”} |
1.5716729131463811e+09 | error | keycloak-gatekeeper/middleware.go:161 | unable to find a refresh token for user | {“client_ip”: “**”, “email”: “”, “error”: “no session state found”} |
So we are “unable to find a refresh token for user” because there is “no session state found” according to the logging.
Anybody any idea how to enable token refresh?
Also posted on stackoverflow: https://stackoverflow.com/questions/58490152/use-keycloak-gatekeeper-in-front-of-backend-api
