Hello everyone. It has been over a month that I am trying to set user session limit for 1 session on keycloak 17. I’ve tried every combination I have found on internet, be it from forum or official documentation, still it does not work. What can be the cause? Thank You
Without knowing what you did/tried, we can’t help that much.
If you can post the config of your auth flow here, perhaps(!) we can help.
Sorry can’t post images, but I made config like the one in documentation Server Administration Guide , however I’ve tried many different combinations I can’t even recall them all, I had session limiter in every subflow, but keycloak keeps adding new sessions.
KC17 user session limiter does not work · keycloak/keycloak · Discussion #25334 · GitHub here are the images of my config
Found this flow that helped me:
SSO Version
From the Keycloak sidebar, click Authentication.
Click New on the Flow Definition page.
Name the new flow, set the flow type to generic and click Save.
Click Add Execution on the Actions menu.
Click User Session Count Limiter if the limit should be applied to a single user. Click Realm Session Count Limiter if the limit should be applied to a group of users.
Return to the flow page.
Set the execution you just created to Required and click Config from the Actions menu in the same line.
Create a name for the execution and configure the authenticator. For User Session Count Limiter, you can select Deny new session or Terminate oldest session as the desired behavior.
From the sidebar, click Identity Providers and click your SSO provider.
Open the Post Login Flow menu and click the flow you just created.
Click Save.
