Azure AD B2B is my service provider and Keycloak is my Identity provider. The protocol is SAML.Azure AD B2B redirects properly to Keycloak. The issue I am facing here is, from the request the user name is not being displayed in the Keycloak login page user name textbox.
Anyway I can display the user name from the request?
Maybe you have to map this value, accesstoken provided by keycloak migth be different from the one provided by Azure AD, check this guide/example mapping a Google variable.
By the way, could you please help me? I saw you did configure Azure AD but I am facing some trouble, i can login with Microsoft Identity Provider, but when I do it on an Angular App, i end up with HTTP Status Code 502 Bad Gateway. Hope you can help
