When trying to set up tracing for keycloak x i encounter this problem when server says i have the subsystem installed:
Installed features: [agroal, authentication, authorization, cdi, dbaas-common, dbaas-datasource-postgresql, hibernate-orm, jdbc-h2, jdbc-mariadb, jdbc-mssql, jdbc-mysql, jdbc-oracle, jdbc-postgresql, keycloak, m2m-manager, narayana-jta, nc-context-propagation-quarkus, nc-framework-contexts-quarkus, netcracker-keycloak-idp-extension, netcracker-keycloak-starter-extension, netcracker-keycloak-um-extension, oidc, reactive-routes, rest-client, resteasy, resteasy-jackson, routes-registration, security, security-common, security-context, smallrye-context-propagation, smallrye-health, smallrye-metrics, **smallrye-opentracing**, vault, vault-client, vertx]
However, none of the relevant properties are being recognized:
[2022-05-06 21:36:03,575] [WARN] [thread=main] [caller=io.quarkus.config] [requestId=] Unrecognized configuration key "quarkus.jaeger.service-name" was provided; it will be ignored; verify that the dependency extension for this configuration is set or that you did not make a typo
[2022-05-06 21:36:03,575] [WARN] [thread=main] [caller=io.quarkus.config] [requestId=] Unrecognized configuration key "quarkus.jaeger.sampler-param" was provided; it will be ignored; verify that the dependency extension for this configuration is set or that you did not make a typo
[2022-05-06 21:36:03,575] [WARN] [thread=main] [caller=io.quarkus.config] [requestId=] Unrecognized configuration key "quarkus.jaeger.sampler-type" was provided; it will be ignored; verify that the dependency extension for this configuration is set or that you did not make a typo
Perhaps there’s a known trick to make it work? All i did was follow quarkus’ tracing tutorial - add smallrye depend, provide config properties and they suggest it’ll just work.
