Hi there,
i have followed the guide to setup passwordless registration and login. I can successfull register a user with Yubikey 5 and i can see the webauthn credentials of the user in Admin console.
But when i try to login the user i get
04:57:50,100 WARN [org.keycloak.services] (default task-17) KC-SERVICES0013: Failed authentication: org.keycloak.authentication.AuthenticationFlowException: authenticator: webauthn-authenticator-passwordless
at org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:438)
at org.keycloak.authentication.DefaultAuthenticationFlow.processFlow(DefaultAuthenticationFlow.java:252)
at org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:386)
at org.keycloak.authentication.DefaultAuthenticationFlow.continueAuthenticationAfterSuccessfulAction(DefaultAuthenticationFlow.java:185)
at org.keycloak.authentication.DefaultAuthenticationFlow.processAction(DefaultAuthenticationFlow.java:163)
at org.keycloak.authentication.AuthenticationProcessor.authenticationAction(AuthenticationProcessor.java:938)
at org.keycloak.services.resources.LoginActionsService.processFlow(LoginActionsService.java:311)
at org.keycloak.services.resources.LoginActionsService.processAuthentication(LoginActionsService.java:282)
at org.keycloak.services.resources.LoginActionsService.authenticate(LoginActionsService.java:266)
at org.keycloak.services.resources.LoginActionsService.authenticateForm(LoginActionsService.java:339)
