I have already used Keycloak API for my application. But I have problems with syncing data between my application and Keycloak data. For example, when sending UPDATE PASSWORD action, I can not confirm if the user updated or not in my app.
Is there any webhook or notification for solving this problem? Or I miss some important documentation about it?
Thanks.
you can write your own event listener SPI and act upon those events. Take a look at https://github.com/zonaut/keycloak-extensions for an example
Is there some recommendations how can I debug?
I created a simple even-listener, and it works locally, but it is silent in DEV server. Trying to find the problem, but no logs regarding even-listeners at all.
- Put some logging in your
EventListenerProvider
andEventListenerProviderFactory
methods, when the factory is initialized, the provider is created, and when theonEvent
methods are called. - Make sure your listener is installed in the event configuration in the admin UI. Add the
jboss-logging
event listener too, which will output events to the logs.
As I mentioned above, my listener is working well in my local environment.
I found the problem.
In local environment I’m using a master realm, and it works well. But in DEV and Production servers I’m using a client realm (different one from master).
If you first time enable an event listener in the client realm, it will not work. First I needed to enable it in the master realm, after in the client, so it works now.
Thank you.
