What is replacement for "credentials token" realm in Keycloak
Hi, I had try to create Realm with name is Teams. Then, I go back to master Realm and check client generated with name “Teams-realm”. I click turn Off on “Enabled” field and save.
It generate Credentials tab and secret credentials can be used to access realm. Fyi, i am using Keycloak 8.0.1 version
How about Red Hat build of Keycloak rhbk/keycloak-rhel9 version 26.0-6 ? There is no button to disable access and create token access , i want to keen use token, please give advice to achieve this goal. Thanks
