Here is a code part of my pinia store, with which I try to abstract the authentication:
The code works for authentication, and I can read the token in other parts via
useAuthStore.istance.token
correctly.
export const useAuthStore = defineStore('auth', {
state: () => ({
instance: null as Keycloak
getters: {
token() {
return this.instance.token
actions: {
setInstance(instance: Keycloak) {
this.instance = instance
async tryAuthentication() {
const kinstance = new Keycloak()
return kinstance.init({
enableLogging: true,
checkLoginIframe: true,
onLoad: "check-sso",
silentCheckSsoRedirectUri: window.location.origin + '/silent-check-sso.html',
.then(function (authenticated) {
if (authenticated) {
useAuthStore().setInstance(kinstance)
console.log(kinstance) //here I have the field: idTokenParsed
console.log("keycloak after init: ", useAuthStore().instance) //here I don't have it
} else {
location.href = kinstance.createLoginUrl();
.catch((e) => {
console.log(`keycloak init exception ${e}`);
My Problem is, that when I checkout the instance of keycloak right in the then()
section, I can get fields like idTokenParsed
, which I cannot read just in the next line, when I get the instance from the store.
Fun fact: the pinia store, when I check the store in the dev-tools, has the fields
BUT: when I try to refresh the token, in the same store:
async refreshToken() {
console.log(this.instance) //fields are missing again
console.log("Token was not refreshed, still valid?:" + this.instance.isTokenExpired(180))
//throws error: not authenticated, because the fields are missing in that instance...
await this.instance.updateToken(180)
.then((refreshed: any) => {
if (refreshed) {
console.log("Token was refreshed")
} else {
console.log("Token was not refreshed")
.catch(() => {
console.log("Cannot refresh token")
I cannot do that, as the fields required are missing …
What did I get wrong?
Somehow I cannot correctly, write and access the instance after init()
with its values after a correct authentication…
